April 5, 2006, 19:04 |
Mass flow rate
Hello All,
I have a mass flow rate (0.0468 kg/s) outlet result for a 2D model and need to apply this to a 3D model for inlet mass flow rate boundary. What does this mass flow rate means in term of 3D? How can I use this result and apply to the 3D model? Thank you |
April 6, 2006, 01:36 |
Re: Mass flow rate
Was your 2D model axisymmetric? If yes then the mass flow rate is real. Apply directly to the 3D model.
October 14, 2010, 00:45 |
contrast case
Dokeun, Hwang
Rep Power: 16 |
hello~ everyone
I have a another question about this post What if I have mass flow rate for 3d and i want to apply that flow rate to 2d axisymmetric casek for reducing computational cost? |
October 14, 2010, 02:33 |
Maxime Perelli
Rep Power: 41 |
Same date for axisymmetric and 3d.
But you can also use velocity inlet, and check the massflow rate (report/)
In memory of my friend Hervé: CFD engineer & freerider |
October 17, 2010, 06:54 |
Marta Lazzarin
Rep Power: 17 |
Dear All, I have simulated a combustion flow in CFX some time ago. It was possible to define a surface which was a wall, but from which some reacting species were inserted into the domain.
This boundary was a wall+source, so that I was able to specify both mass fractions of the various species and the mass flow rate coming in; it was also possible to have a certain heat flux at that boundary. It was one of the parameters calculated during the simulation. Is there a similar condition in Fluent? 'cause i saw just traditional walls and mass flow inlet boundaries. If not, is there any other way to make Fluent do what i need? (which is basically introducing a certain amount of mass from the boundary, with specified mass fractions and calculating the heat flux without imposing it at the beginning). Thanks a lot Marta |
July 30, 2013, 15:42 |
Negative mass flow rate in everywhere except inlet
Tanjina Afrin
Rep Power: 13 |
Hi all,
In my 2D model, I found negative mass flow rate in everywhere except in the inlet. What does it mean? Please enlighten me . Thanks in advance. |
July 30, 2013, 17:03 |
Alex
Rep Power: 49 |
It means that the flow exits the computational domain.
July 30, 2013, 17:52 |
Tanjina Afrin
Rep Power: 13 |
July 30, 2013, 18:27 |
#9 |
Alex
Rep Power: 49 |
Boundary faces like an inlet have an orientation, indicated by the normal vector of the face.
For example the normal vector of the inlet face points towards the computational domain. If the flux vector is pointing in the same direction, the mass flow rate is positive (the flow enters the computational domain). For faces where the normal vector and the flux vector are pointing in opposite directions, the mass flow rate is negative. For an outlet this indicates that the flow is leaving the domain. |
July 30, 2013, 18:50 |
#10 | |
Tanjina Afrin
Rep Power: 13 |
July 28, 2014, 23:39 |
negative mass flow rate at outlet
#11 |
Rep Power: 14 |
I am facing the same problem of negative mass flow rate & I don't quite understand what's meant by the fluid's leaving the domain.
Isn't the direction of my flow supposed to be the same at all positions? and that's what I'm getting when I display the velocity vectors, then how come my mass flow rate is negative? Please help me understand this. |
July 29, 2014, 05:17 |
#12 | ||
Rep Power: 27 |
August 12, 2014, 10:15 |
#13 |
Rep Power: 14 |
Thanks a lot Pakk, that was really helpful
July 19, 2017, 08:01 |
Flow rate
#14 |
saeed
Rep Power: 17 |
Hi all
I want to measure Flow rate in a Manifold with one inlet and two outlet in Fluent. my question is that, how can I measure the flow rate at the beginning of every path? In Report.....could be just measure the flow rate in Inlet and Outlet. I used the Iso Surface to define a surface but because entrances of both of the paths are in a same surface, I need a way to define a surface for every path separately!! Thanks alot (I attached my model's pic) |
July 19, 2017, 10:04 |
#15 |
Rep Power: 12 |
So you want to check the mass flow in the two outlet channels? The reports for both of the outlets would suffice surely, but if you would like to check how the flow field develops in the y direction, you could just creat a surface (y=0 m or something like that which would intersect both of the channels) and then iso-clip them into submission. Now you have two separate surfaces for your monitoring pleasures!
July 19, 2017, 10:31 |
#16 |
saeed
Rep Power: 17 |
Thanks a milllllllion divergence my problem was solved
by your guidance, Thanks alot |
Particle Injection Mass Flow Rate and Position | leonozx | FLUENT | 3 | March 9, 2018 10:58 |
CFX turbo - Mass flow rate | Vashishth Patel | CFX | 7 | April 3, 2014 21:33 |
Mass flow rate at the outlet | tejasvikrishna | FLUENT | 2 | May 25, 2013 03:42 |
negative global mass flow rate | Gimli | FLUENT | 0 | April 21, 2006 08:17 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 01:32 |
