How can I compare the results of different mesh an
Like Tree1Likes
  • 1 Post By ANJUM NAVEED
Old   February 16, 2006, 20:45
Default How can I compare the results of different mesh an
nan
I got the unsteady analysis results of a tank model which used different meshes. I used different under relaxation settings(moment, pressure) in order to avoid turbulent viscosity limit.
But in some timesteps, their features of flow differ greatly.
Can I compare these results directly?
Any help will be very much appreciated. Thanks.
Old   February 17, 2006, 04:14
Default Re: How can I compare the results of different mes
ANJUM NAVEED
hi if you want to compare results of two different meshes. save result of first mesh by your xy plot window by write. and when you plot result for second mesh in that xy plot window click load file and then browse to your previous save file. you will see both results in same window. best wishes Anjum
Old   February 20, 2006, 22:18
nan
Thank you, Anjum!
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
Difference in results using different Mesh? Julie FLUENT 7 July 2, 2002 11:28
