Pressure coefficient
Like Tree1Likes
  • 1 Post By itoalberti
Old   February 4, 2006, 06:07
Default Pressure coefficient
Giuseppe
Hello to all,
I have studied, with Fluent, the problem of flow past a circular cylinder in a uniform stream and I have plotted in XY graphics the pressure coefficient vs position(m). I have obtained two curves, one for the upper surface and one another for the lower surface!
The questions are:
1) The direction of the pressure coefficient is orthogonal to the cylinder surface?
2) How can I plot the pressure coefficient distribution only for the upper surface and only for the lower surface, in two separate graphics?
3) How can I plot, in Fluent, the pressure coefficient vs angle?
Thanks a lot
Old   July 24, 2015, 12:03
Mauricio
itoalberti is on a distinguished road
You can create an Iso-clip located on the cylinder wall and with visibility criteria of y>=0 if you want to plot only for positive y
Also, I've tried to plot Cp x theta but haven't found any help on that, so I'm taking that it's not possible to do that on Ansys. I'm using Excel to transform from Cartesian to cylindrical coordinates...
jzc likes this.
itoalberti is offline   Reply With Quote
Old   July 26, 2015, 04:19
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
you can try tutorials which I gather on my blog
links below
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD)
https://howtooansys.blogspot.com/
Martin_Sz is offline   Reply With Quote
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 02:40
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 11:52
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
Problem in Result of the pressure coefficient Ken Choi Main CFD Forum 2 March 15, 1999 05:15
