How to calculate Turbulent Intensity? |
Could any one please guide me on how to calculate the turbulent intensity..While doing k-epsilon turbulent modeling I chose Turbulent Intensity and Hydraulic Diameter Option.Please Help me in this regard.Thanks in Advance
hi prem It is there in Fluent manual. turbulance Intensity = 0.16*{(Re)power(-1/8)} hydraulic dia. for circular section it is equal to diameter of section and for any other section it is sqrt(4*A/pie), where A is area if section . it will be better if u have a look of manual.
HI balmiki thanks a lot for your guidance
#4 | |
Rep Power: 16 ![]() |
I know this is an old topic... But why is the intensity irreversible proportional to the Reynolds number? I would expect that the intensity increases for a higher Reynolds number |
#5 | |
Nawar
Rep Power: 0 ![]() |
i want to ask is there any formula for calculating the turbulent intensity of an internal flow in a pipe in the case of non-fully developed flow i do know how to use the formula of I=0.16〖(Re)〗^(-1/8), but this formula,as i think, can be used only for fully developed flow. thanks nawar |
Svetlin Filipov
Rep Power: 17 ![]() |
Fluent manual point two methods for calculating: one for internal flows and one for external....
Estimating the turbulence intensity
When setting boundary conditions for a CFD simulation it is often necessary to estimate the turbulence intensity on the inlets. To do this accurately it is good to have some form of measurements or previous experince to base the estimate on. Here are a few examples of common estimations of the incoming turbulence intensity:
Luke
Rep Power: 15 ![]() |
For 3D external flow around a 3D wheel, bounded by 'parallel' boundaries, what would the boundary conditions for the velocity inlet be in this case? The velocity inlet is 70m/s in my case. (actually simulating the wheel moving at 70m/s, but instead the wheel stationary and the air moving over it). Using the equation previously stated, 'I' comes out at 0.0224 (so 2.24%?). Regarding the second boundary condition, I thought Hydraulic Diameter was not appropriate because the eddies wouldn't be restricted by any boundaries in external flow, so would I used 'Length Scale' as have it has the wheel diameter?
I'm a bit confused as the literature doesn't really define a case like mine. |
#9 | |
Yes, there is no literature about turbulent length scale for external flow!!! ![]() ![]() ![]() ![]() ![]() |
#10 |
YACOUBI Seif Eddine
Rep Power: 8 ![]() |
#11 |
YACOUBI Seif Eddine
A turbulence intensity of 1% or less is generally considered low and turbulence intensities greater than 10% are considered high. Ideally, you will have a good estimate of the turbulence intensity at the inlet boundary from external, measured data. For example, if you are simulating a wind-tunnel experiment, the turbulence intensity in the free stream is usually available from the tunnel characteristics. In modern low-turbulence wind tunnels, the free-stream turbulence intensity may be as low as 0.05%.
For internal flows, the turbulence intensity at the inlets is totally dependent on the upstream history of the flow. If the flow upstream is under-developed and undisturbed, you can use a low turbulence intensity. If the flow is fully developed, the turbulence intensity may be as high as a few percent. The turbulence intensity at the core of a fully-developed duct flow can be estimated from the following formula derived from an empirical correlation for pipe flows: ![]() At a Reynolds number of 50,000, for example, the turbulence intensity will be 4%, according to this formula. |
k-epsilon: Defining turbulent intensity and length scale? | klausb | OpenFOAM | 0 | January 23, 2011 07:28 |
Turbulent intensity | swe704 | Main CFD Forum | 0 | November 13, 2009 03:42 |
how to calculate Turbulent Length Scale | nuimlabib | Main CFD Forum | 2 | August 18, 2009 04:22 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
calculate k and epsilon from turbulent intensity | Ralf Schmidt | Main CFD Forum | 6 | March 24, 2006 05:50 |
