how to calculate electrical potential with UDF?
Like Tree1Likes
  • 1 Post By Josh
Old   January 6, 2006, 12:35
Default how to calculate electrical potential with UDF?
josh
I read in paper that the electricval potential can be coded as user defined acalar transport equations in FLUENT but how to write the code and set boundary conditions and meterial properties?
Thank you for any help.
Old   January 18, 2006, 07:13
Default Re: how to calculate electrical potential with UDF
kharicha
First have a look in FLUENT documentation about UDS. Make a comparison between the UDS equation in Fluent, and the electric potential equation.
If you simulate an imposed current or potential, there is no source to add...it will be easy.
You have to write a source (UDF) function of the velocity gradient if the potential results from an interaction between the flow and a magnetic field. This is much more complicated.
keep in touch.
Abdellah
Old   January 18, 2006, 08:56
Ralf Schmidt
I am thinking about a simulation of the air flow through a plasma field. There is an ionization taking place - can this be simulated with fluent?
If yes, how? Does someone know the equations or can give me any paper?
Ralf
Old   January 19, 2006, 04:44
kharicha
Your plasma has a constant or varying (time) ions concentration?
I need to see the equations that you want to solve... then I will be able to answer you.
Old   January 24, 2006, 12:34
Josh
Your messege is very helpful. I will try to solve a laplace field first. I may still need your help for writing the UDF file. Thanks a lot.
linda0626zhjj likes this.
UDF using c_face_loop(c,t,i) frederic FLUENT 3 January 17, 2017 00:17
Does Fluent Calculate VOF before Momentum ? Ganapathy Fluent UDF and Scheme Programming 1 April 7, 2010 11:56
How to calculate second order derivatives using udf? legendyxg Fluent UDF and Scheme Programming 0 October 6, 2009 23:05
Help: how to realize UDF on parallel cluster? Haoyin FLUENT 1 August 6, 2007 14:53
DEFINE_GEOM UDF Problems Pat FLUENT 0 August 14, 2003 14:16
