Energy Source Help!
Like Tree1Likes
  • 1 Post By Andrew Clark
Old   October 24, 2005, 15:17
Default Energy Source Help!
Andrew Clark
I just want to clarify that I am using the Energy Source function correctly (the option under Fluids)
I am attempting to take a tube with air flowing through it and inject a fuel into the flow at a certain mass, momentum and temperature. Note that I am using an inviscid coupled solver, so I cannot fix the temperature which I would have liked to have done
I have figured out how to set the mass and momentum correctly as they are clearly stated in the user guide, however I am having problems setting the energy source correctly.
It is my understanding that for inviscid flow:
E = h + p/rho
So for example if my temperature is 750K, the Cp is 1000, standard state temperature is 298.15K and the standard state enthalpy is 0, I can find h from:
h = 1000*(750-298.5) + 0
Where would I get the pressure and density from? Are these the reference values, or the conditions of the source? The reason I question this, when I change the reference values, this has an effect on the final temperature of the source (that being once a cooler air has flowed over it)?
Also is there anyway to verify I set the conditions correctly in Fluent, because when the air flows through the tube (at 200K), it also flow over the source therefore changing the temperature so I have no way of checking to make sure my source is in fact at 750K.
Thank you
Andrew
ddmdddghj likes this.
Old   October 24, 2005, 15:39
Default Momentum Equation for Porous Media
Sherry
I tried to write down the governing equations for multi-phase flow in a porous medium. Does anybody know whether the velocity used in equation (7.19-30) of users guide is the physical velocity. If so, I think there are some problems for this equation compared to other models we usually use. Can I use the UDF to define the whole momentum equation by myself?
Thanks a lot. I hope I can find someone who also use fluent to simulate the porous media and can give me some advices about it.
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 13:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
