Enhanced Wall Treatment - Thermal Effects
Like Tree1Likes
  • 1 Post By balaji_hrrn
Old   October 17, 2005, 10:00
Default Enhanced Wall Treatment - Thermal Effects
Brian Tang
Hi, I'm using Fluent 6.1 with EWT, but I'm not entirely sure what the two options (thermal effects and pressure gradients) do. From the manual, it seems that it sensitises the enhanced wall function to heat transfer effects and pressure gradients, but I'm slightly confused: Does this mean that I only need to turn on thermal effects if I expect large heat transfer to/from the boundary layer, or will I need this option to get accurate heat transfer predictions?
Thanks, Brian
Old   November 6, 2015, 00:59
balaji_hrrn's Avatar
Fluidic Heat
balaji_hrrn is on a distinguished road
http://www.afs.enea.it/project/neptu...#trb-du_dy-mod
This link will explain what this mathematically means. Beta and Gamma functions are the near wall thermal functions based on log-wall treatment, while alpha is for the pressure effects.
Notice that the alpha is inversely proportional to cube of velocity, which implies that for simulations having high velocity gradients in the Boundary Layer and with Ideal Gas materials, these terms become important to be modeled.
For eg. a hot gas flow from a combustor outlet must have both of these turned on, while for a case where pressure effects are predominant compared to thermal effects due to low residence times, pressure gradient effects should be enabled.
triimaran likes this.
balaji_hrrn is offline   Reply With Quote
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
k-epsilon, enhanced wall treatment mmmiichaalll FLUENT 4 March 30, 2010 06:10
Near Wall treatment sven OpenFOAM 1 September 13, 2009 21:57
Wall treatment for high Pr fluid Jessica FLUENT 0 July 31, 2008 23:53
LES wall treatment Valerio FLUENT 0 April 26, 2008 08:12
