Methane combustion
Like Tree3Likes
  • 2 Post By Micael
  • 1 Post By sberg
Old   August 5, 2005, 06:51
Default Methane combustion
Steve
Has anyone tried the Jones and Lindstedt four equation mechanism for methane combustion in Fluent?
I have implemented the four steps in the "propdb.scm" file. It works fine for the EDM, but when EDC is activated Fluent gives the error message:
********** ISAT_ABORT ************** routine = phi2y location = 1 message = non-positive species sum
****** END ISAT_ABORT **************
Error: isat terminated. Error Object: #f
Does anyone know how to implement this mechanism in Fluent so the EDC works?
Steve
Old   November 17, 2011, 22:26
Default Hi
San Siro
San Siro is on a distinguished road
Originally Posted by Steve
;123005
Steve
Hi Steve,I encountered the same question just like you did.I'm wondering if you have solved this problem.Looking forward to you reply.
San Siro is offline   Reply With Quote
Old   November 18, 2011, 08:07
Default Hi San Siro
Steve Berg
sberg is on a distinguished road
At that time I contacted Fluent support and they said I had to use a Chemkin file. They even provided me the file. It's named 4_reactions.che and I attached it below. As far as I remembered the Chemkin file ran smoothly with the EDC model in Fluent 5.3 and 6. I hope it will work for you as well.
Kind regards
Steve
ELEMENTS
H O C N
END
SPECIES
CH4 O2 CO2 CO H2O H2 N2
END
THERMO
END
REACTIONS KJOULES/MOLE
!Units are cm, mol, s, kJ/mol and K.
2CH4+O2=>2CO+4H2 7.824435194e13 0.0 0.12552
FORD/CH4 0.5/O2 1.25/
CH4+H2O=>CO+3H2 3.1E11 0.0 0.12552
CO+H2O=>CO2+H2 2.75E12 0.0 0.08368
2H2+O2<=>2H2O 4.44566E21 -1.0 0.16736
FORD/H2 0.5/O2 2.25/
RORD/H2O -1.0/
END
sberg is offline   Reply With Quote
Old   November 22, 2011, 23:03
Default HI
San Siro
When I used the laminal finite-rate model to simulate a reaction involves both volumetric reactions and wall surface reactions,I selected the Two-Step Solution Procedure.I begin by solving the flow, energy, and species equations with reactions disabled.When the basic flow pattern has been established,I enable the reactions and continue the calculation.
Then fluent gives the error message:
Error: Non-physical Specific Heat = 0.000000e+000.
Error Object: ()
I ignore the message and continue to calculate,fluent gives the following error message:
Error Object: ().
This problem has troubled me for a long time.Is there any suggestions how can I solve this problem and continue my calculation.
Thank
San Siro
Old   March 9, 2012, 17:04
Micael
Micael is on a distinguished road
Kind regards
Steve
ELEMENTS
H O C N
END
SPECIES
END
THERMO
END
RORD/H2O -1.0/
END
How reverse order for H2O should be interpreted? It is written as -1 (minus one). What the minus sign means? I mean, it is unphysical to have a negative order, that would mean the less concentration, the fastest kinetic (and infinite kinetic at zero concentration!)
Edit: My guess so far is that adding a minus or plus sign mean a correction on the order. Anybody can confirm?
Micael is offline   Reply With Quote
Old   March 9, 2012, 20:05
Steve Berg
The H2 + 0.5 O2 --> H2O reaction is a global one and it includes several elementary steps with many reactive intermediates like H, O, OH. Such global reactions have complicated rate laws. The reaction orders are usually not integers and they can be negative.
You can probably find some more details, if you are interested, in Warnatz, Maas and Dibble's textbook "Combustion."
Old   March 9, 2012, 20:28
Steve Berg
And of course, a negative reaction order means the rate decreases when the concentration of that component increases
r = k(T) [H2]^0.5 [O2]^2.25 [H2O]^(-1) = k(T) [H2]^0.5 [O2]^2.25 / [H2O]
amin_jalalian likes this.
Old   March 10, 2012, 18:25
Micael
Thanks for your reply.
It is still not clear to me. I thought the chemkin format means:
r = kf(T) [H2]^0.5 [O2]^2.25 - kb(T) [H2O]^(-1)
kf: forward constant
kb: reverse constant
Of course, put this way, it does not make sense (as the product decrease, the reverse kinetic increase).
Looking at the file, it seems that the reaction is considered reversible. The way you put it, I don't see how it can be reversible.
Old   March 10, 2012, 20:04
Steve Berg
Yes, you are correct.
2H2+O2<=>2H2O is often simplified to be non-reversible and represented by r = k(T) [H2]^0.5 [O2]^2.25 [H2O]^(-1). But according to the Chemkin output, as you noticed, it isn't the case. The reaction seems to be reversible with a reaction order of -1.
Old   April 1, 2014, 18:33
Default Different version of chemkin
Kevin
leexit is on a distinguished road
Hi
I just wonder if the chemkin file that is available in Fluent can be older version of chemkin. I use CHEMKIN-II Version 3.1 and do not think it allows me to enter the reaction order. Has anyone ever tried to use the Jones and Lindstedt mechanism with my version of chemkin?
Thank you in advance
leexit is offline   Reply With Quote
Old   March 17, 2021, 08:40
Prashant Gahlot
Prashantgahlot is on a distinguished road
Kind regards
Steve
ELEMENTS
H O C N
END
SPECIES
END
THERMO
END
RORD/H2O -1.0/
END
Tried this in my fluent, but its showing floating point error. Can Somebody please guide me through this?
Prashantgahlot is offline   Reply With Quote
Temperature drops in Methane combustion CPRL Siemens 0 July 24, 2007 13:56
How to model combustion with only methane stream? ligang zheng FLUENT 2 May 1, 2007 10:16
Methane combustion in gas burner Stefano CFX 1 June 7, 2005 03:12
Presumed PDF for methane combustion Andreas Siemens 0 May 21, 2003 10:07
Methane Combustion Lars FLUENT 4 March 5, 2003 09:24
