Open Channel Flow - Setting Boundary Conditions
Like Tree3Likes
  • 1 Post By Christine Sindelar
  • 1 Post By suryakant
  • 1 Post By Mehdi Ghoddosy
Old   July 26, 2005, 07:29
Default Open Channel Flow - Setting Boundary Conditions
Christine Sindelar
Hallo everybody!
I've only just begun to work with Fluent (V6.2). I want to use the VOF model to simulate an open channel flow. My geometry consists of the river bed (trapezoidal cross-section, water level approx. 5m) and a layer of air above it. I'm not clear about how to set the boundary conditions (BC).
Which area has to be taken for the inlet? Just the area where the water enters or also the area of air?
I'm grateful for any advise!
Christine
indranil likes this.
Old   July 26, 2005, 08:00
Default Re: Open Channel Flow - Setting Boundary Condition
suryakant
hi chirs..... me too new to fluent but i guess u will have to specify the in let as both air and water crossections.....try it ....it might just work....best of luck
Everton likes this.
Old   July 27, 2005, 01:29
Mehdi Ghoddosy
Dear Christine:
You can use all of boundary condition types in VOF open channel model. However, Mass flow inlet and pressure outlet/inlet are preffered and more used. But, you have to choose the boundary condition based on the problem specifications. If you know the flowrate, use mass flow inlet. I this boundary condition type, you can set the initial water level(would be changed during solve) and specified constant water and air mass flowrate. But if you know the water level and change of flowrate is not important choose pressure inlet/outlet BC. In this BC you do not need to enter air flowrate, and just enter free surface water level. However, if the wind effects in negligible in your problem, it is not nesseecary to enter air flowrate. Also, you can choose combinations of other BC for modeling your problem. Remember to DO NOT choose preesure inlet for upper boundary(atmosphere). Althogh is seems logical but causes divergence.
I recommend to use smaller model, considering scale effects in river flow modelling, if possible. If you want to study on secondary flows or compound channel, use scaled model, because you have to define very large mesh on this geometry and your CPU consumed time will be too long. but, if meandering effects is important do not use scaled model.
Wish to be useful.
Best Regards
Mehdi Ghoddosy
Everton likes this.
Old   July 30, 2005, 07:59
Mehdi Ghoddosy
Dear Christine:
Reading these two papers can give you a valuable help and vision:
Matthews, C. A., et al..;"Computaions of Curved Free Surface Water Flow On Spiral Concentrators"; ASCE journal of hydraulic engineering, Vol.125,pp??,Nov. 1999,
and related discussion as:
Fabian, A., et al.; ASCE journal of hydraulic engineering, pp629-631,July 2001
Best Regards
Mehdi Ghoddosy
Old   August 1, 2005, 04:54
Christine Sindelar
Dear Mehdi,
thank you. That was very useful. I happened to find both publications in our library.
Best regards Christine
Old   July 15, 2009, 14:46
Default Solving the same problem for my MS
mechovator
mechovator is on a distinguished road
Hello dear christine.
I just saw your problem and learned that you got its solution. I have just started my MS and am working in the same field. It would be very nice of you if you could please help me. Feel free to contact me on
mechovator@yahoo.com
With best regards
Mechovator
mechovator is offline   Reply With Quote
Old   June 6, 2011, 05:11
Default open channel flow(moving mesh)
sara saleh
s_saleh is on a distinguished road
Hi Dear Ghoddosy
I am working with fluent (v. 12) and I want to model an 2d open channel with a wheel in open channel that raotates and moves the water in channel.
I have problems with boundary conditions.for setting BC in water and air.
should I set separate BC for water and air region?how?
regards
Saleh
s_saleh is offline   Reply With Quote
Open Channel Flow Boundary Conditions TWaung STAR-CCM+ 2 October 7, 2011 01:37
Open Channel Flow Boundary Conditions. rahulrp FLUENT 0 December 1, 2010 08:32
how to use Up Stream boundary condition in open channel Flow ms.jafarinik FLUENT 0 April 18, 2010 15:38
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
