eulerian multiphase flow(gas-solid)
Like Tree2Likes
  • 1 Post By Masood
  • 1 Post By Owen
Old   July 26, 2005, 07:01
Default eulerian multiphase flow(gas-solid)
Masood
what is the diffrence between volume of fraction in patch section and porosity in boundary condition(fluid zone for mixture)?it means what should i do for defining of a solid bed with voidage=0.5? my case is fluidized bed. regards
souza.emer likes this.
Old   July 28, 2005, 03:53
Default Re: eulerian multiphase flow(gas-solid)
Owen
I think you will find that porosity is for a fixed bed. To simulate a fluidised bed, patch the volume fraction - however depending on the conditions you may find that it settles out before becoming fluidised. Unless you are modelling startup of the settled bed it may not be wise to patch the bed with solid at 0.5 fraction.
I have been modelling a fluidised catalytic cracker which may be similar to your fluidised bed. I found better convergance by starting with an empty vessel and allowing the solid to enter with the gas through the inlet. It takes some time to reach a 'steady state' but diverged less than when I patched the bed initially.
Good luck,
Owen
Old   July 28, 2005, 11:33
masood
Dear Owen! i dont know yet that,if i patch vof of solid and determine partocle diameter,is it need to define porosity in fluid zone for solid or no?i want to simulate batch fluidized bed(not continious) ,then i cant allow particles to enter with gas! regards
Old   July 29, 2005, 05:41
Owen
Woah, long question Masood. I'll attempt to answer it for you.
For Eulerian multiphase model you can specify your catalyst properties under Define_Phases. Make phase 2 your catalyst, check the 'Granular' box, then you can set the particle diameter here .
Now you can patch a region with solid particles to the solid fraction that you wish - depending on how much the particles settle or are fluidised in operation, will determine the porosity of your bed.
The maximum packing factor for the solid will determine the maximum solid fraction you can patch initially. This is set under Define_phases_phase 2. It has a default value of 0.63.
One last point if the bulk of your bed is stationary there is an option for Fixed Bed under phase options which you should read about in the documentation and decide if it's suitable for your problem.
Cheers,
Owen
mesh size in Eulerian multiphase flow - liquid/solid mixture microfin FLUENT 4 December 23, 2016 14:55
multiphase... solid volume fraction anomaly Tim CFX 4 February 14, 2012 05:01
Two phase Eulerian model with variable solid density ziglat2004 FLUENT 0 September 16, 2011 19:06
Multiphase Euler-Euler / gas solid Dr. Flow Squad CFX 1 November 27, 2007 10:52
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
