Outlet vent vs Outflow
Like Tree6Likes
  • 6 Post By Jason
Old   July 19, 2005, 11:37
Default Outlet vent vs Outflow
AJG
Does anybody can explain to me what is the difference between outlet vent and outflow?
thanks
AJG
Old   July 19, 2005, 15:16
Default Re: Outlet vent vs Outflow
Jason
Outflow is a very limited BC. It assumes fully developed flow, can't be used with Pressure Inlets, or compressible flow. It is useful in pipeflows for example, when you don't know the conditions of the flow, but you're BC is far enough downstream where the fully developed assumption holds true.
The outlet vent is like a pressure outlet (so it's a pretty versatile BC) combined with a loss coefficient. Here, you define what the pressure is "outside" of your vent, and the loss coefficient (which is a function of velocity) through the vent, and the backflow conditions. An example would be on an electronics box (like a computer). A fan would pull cool air into the box, and it would exit through a vent. The vent is going to induce some losses on the system (if you invent a vent that doesn't, then patent it and we'll split the profits...) and this BC is used to account for that.
Hope this helps, and good luck, Jason
Old   July 20, 2005, 13:59
AJG
Thanks man! really helpful your answer. AJG
Old   June 7, 2019, 05:12
Amey Raju Pawade
amey169 is on a distinguished road
Its been a long time for this thread, but hope someone replies to my query.
The loss coefficient which we provide for pressure drop through the vent, which pressure drop does it accounts for - the static pressure or total pressure?
amey169 is offline   Reply With Quote
not outflow at outlet in interFoam deniggo OpenFOAM 15 May 17, 2022 07:06
Outlet Vent Loss Coefficient jpo FLUENT 0 June 24, 2009 20:15
B.C.S on outflow outlet and pressure outlet kenneth Main CFD Forum 4 May 29, 2008 21:57
HELP !!difference of outflow and pressure outlet?? Kwong FLUENT 1 April 11, 2007 06:04
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 09:07
