Can anyone suggest how I can plot Q criterion in fluent to visualize the coherent structures?
Thanks for your help. Anindya |
hi anindya,
you certainly have the definition of that q criterion which is based on velocity gradient. Fluent do not provide it directly,i mean you have to compose it from computed velocity gradient as a custom field function. for that: define>custom field function and type the name of the criterion "q" for example. you will be then able to visualize the q value on a specified surface on the contour panel... if you want to create an animation of an iso-q surface for example you also have to create an isosurface, hope it helps. best regards Said |
Thanks a lot for your message. I have already created that custom field function Q.
So when I create iso-surfaces, do I create iso surfaces of Q ( say specific values of Q) and then plot Q on those Q iso-surfaces? Or do I plot Q on iso-surfaces of low pressure, vorticity-maginitude, etc? Anindya |
Fortunately, you don't have to use UDF. Here's a simpler way of visualizing the iso-contours of the second-invariant.
You can use the custom field funtion capbility in FLUENT. First you define the second-invariant of deformation tensor with Q = 0.5(W*W - S*S) where W is the vorticity magnitude (you can find it under the "Velocity" menu) and S is the mean rate-of-strain (you can find it under "Derivatives" menu). Once you defined Q, you can generate iso-surfaces of Q for several positive values. |
Thanks a lot for your help.
Anindya |
#6 | |
Rep Power: 16 ![]() |
Hi Guys, should not it be the following: Q=0.25*(W*W - S*S) ??? As the mean rate-of-strain (scalar) is defined as: S=(2Sij*Sij)^0.5 and similarly the vorticity magnitude (scalar): W=(2Wij*Wij)^0.5 with Sij being the mean rate of strain tensor and with Wij the mean vorticity tensor (besides, Sij=symmetric, while Wij=antisymmetric part of mean velocity gradient tensor). Finally the second invariant of velocity grad tensor is defined as: Q=0.5*(Wij*Wij - Sij*Sij). So I think Q should be: Q=0.25*(W*W - S*S). Is that right? Besides, this formula of Q is only valid for incompressible flows, more precisely for flows with divergence free velocity field so that divUj=0 <=> Sii=0 ! Thanks! Last edited by la7low; March 22, 2011 at 20:31. |
Mohamed Ashar
Rep Power: 15 ![]() |
Hi la7low,
Could you please give the reference, from where you have taken this Q criterion. Thanks Last edited by ashar_md2001; October 22, 2012 at 08:52. |
#9 |
Subhasish Mitra
Q criterion was proposed by Jeong & Hussain (1995), J.Fluid Mech., vol.285, pp.69-94.
SM ![]() |
#10 |
C. Meraner
Rep Power: 0 ![]() |
According to "F.R. Menter, Best Practice: Scale-Resolving Simulations in ANSYS CFD, Version 2.00, November 2015" it is: "[...] for historic reasons 0.5 in ANSYS Fluent and 0.25 in ANSYS CFD-Post". However, I don't know how it is in ANSYS CFX.
#11 | |
Subhasish Mitra
1. Q criterion: positive second invariant of velocity gradient tensor HUNT,J . C. R., WRAY, A.A., & MOIN, P. 1988 Eddies, stream, and convergence zones in turbulent flows. Center for Turbulence Research Report CTR-S88, p. 193. 2. Discriminant (DELTA) criterion: complex eigenvalues of velocity gradient tensor CHONG, M.S., PERRY, A.E. & CANTWELL, B. J. 1990 A general classification of three-dimensional flow field. Phys. Fluids A 2, 765. 3. Lambda 2 criterion: negative second eigenvalue of the S^2 + W^2 tensor where S = strain rate tensor (symmetric part of velocity gradient tensor) and W = vorticity tensor (antisymmetric part of velocity gradient tensor) Jeong & Hussain (1995), J.Fluid Mech., vol.285, pp.69-94.
SM ![]() |
#12 |
amir
Rep Power: 11 ![]() |
How can we plot Q criterion, Discriminant (DELTA) criterion, and Lambda 2 criterion in a 2D plane. what is an important plot to draw?
#13 |
This reference may be helpful for defining different vortex detection criteria in 2d
http://aip.scitation.org/doi/10.1063/1.4927647 |
#14 | |
Reviewer #2
Ps: If I am not wrong, I remember is due to some historical reason to use 0.5 and 0.25 in Fluent |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Load written xy plot then FLUENT close automatically | khimkhim | FLUENT | 0 | March 15, 2010 23:49 |
Can Fluent plot p-v or T-s diagram? | Renold | FLUENT | 0 | December 8, 2009 12:00 |
X-Y plot of Yplus in Fluent 5.3 | Luo | FLUENT | 24 | April 11, 2000 06:07 |
