how can I create a curved line in Fluent
Like Tree3Likes
  • 3 Post By dirk
Old   July 4, 2005, 07:35
Default how can I create a curved line in Fluent
antonietta paulozza
hi, I have a cilynder surface and I want to plot the pressure along a line of lateral surface, therefore on a curved line (an arc) of the lateral surface.I have a 3d symmetric domain.I need to define a curved line not necessarly on the boundary but about 1mm inside the boundary.
how can I define a curved line in Fluent domain? I know how to create isosurface or line, but not a curved line. thanks a lot antonietta
Old   July 4, 2005, 09:20
Default Re: how can I create a curved line in Fluent
dirk
You could create an isosurface with constant cell-wall-distance and then clip a surface with constant x (if x-axis is the axis of the cylinder).
Dirk
Old   December 24, 2010, 23:55
NH
NH_Aus is on a distinguished road
Send a message via Skype™ to NH_Aus
Originally Posted by dirk
;122024
Dirk
Could I set a dpm trap boundary condition on the clipped surface?
docnurulhasan@gmail.com
NH_Aus is offline   Reply With Quote
Old   December 25, 2010, 03:40
NH
Originally Posted by antonietta paulozza
;122021
I need to know the shortest distance of wall from the particle location. I know I can use C_WALL_DIST(c,t) this, but how do I connect from:
px=P_POS(p)[0] ;
py=P_POS(p)[1] ;
pz=P_POS(p)[2] ;
Fluent from command line not in background please! Chris Bailey FLUENT 5 July 28, 2012 08:26
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
[Gmsh] GMSH and OpenFOAM derath OpenFOAM Meshing & Mesh Conversion 44 September 4, 2008 06:09
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
