Two phase flow in porous media
Like Tree1Likes
  • 1 Post By Madhavi Krishnan
Old   May 31, 2005, 04:22
Default Two phase flow in porous media
Madhavi Krishnan
I am a new user in Fluent.
I have both water and air flowing through porous media. The flow rate of water (laminar) and the viscous resistance coefficients for the flow of water in the porous media are known.
Air flows into the porous media by natural circulation (hence,its velocity is not known). But the viscous resistance coefficients for its flow through the porous media are known.
The porosity of the porous media is known.
I want to see the flow profiles of both water and air inside the porous media.
How should I proceed?Should I use Mutltiphase models?If so, what model? As far as I have seen,these models ask for too many details like diameter of the secondary phase,drag coefficients,lift force,momentum exchange coefficients etc, which are not known in my case.
Can I solve my problem by Fluent?
Kindly help,
Madhavi.
olliko likes this.
Old   May 31, 2005, 04:40
Default Re: Two phase flow in porous media
Sundar
Hello Madhavi,
There are other ways to handle this problem. Do you have hotmail msn ?
Sun
Old   June 1, 2005, 12:03
thomas
Well i would be very very interested to know what other way you are proposing !
Old   June 6, 2005, 06:52
A.Naser A.Aziz
me 2! It will be very helpful to me in my project. Pls informe.
flow thru porous media, PLEASE HELP Goker FLUENT 4 September 8, 2012 05:02
multiphase flow in porous media zhou FLUENT 2 August 9, 2012 08:10
Porous media flow with diffusion albertinho OpenFOAM 0 March 31, 2010 18:14
Testing the integrity of POROUS media and por jump Azman FLUENT 0 July 31, 2006 12:11
porous media flow Siraj Siemens 4 February 24, 2006 23:24
