flat plate transition: SST k-omega divergence |
I use SST k-omega (transitional version) to model flat plate transition.
Skin friction at 8000 iterations looks realisticaly, but then diverges. BL after transition point behaves like fully laminar (unstable waves). I have tried to lower y+ (from 1.5 to 0.3), lower courant number (3 -> 0.3), lower k-w underrelaxations, but with no success. It always diverges (even after 100 000 iterations). Do you have any ideas? I have put example on: http://www.iol.sk/~mgasparovicova/cfd_test/diverg.htm |
man, are you crazy? for a velocity of 10 m/s you use coupled implicit solver? it will always diverge at such a small velocity! use segregated solver. it was designed just for that. coupled is only for high velocity flows (M>0.6).
Thank you Razvan. As uninitiated self-taught person I always used coupled implicit for 2D problems (where the memory demand is not issue). Sometime I had to use low Cour.n. during whole computation, but I accounted complex turbulence models for it. Sometime I had strange divergence problems even with very simple geometries. Now I see the reason. Thank you much again.
Hello Peter. First of all, I want to say that I am sorry for the language used in the first message I posted for you, but also to tell you that I have very big expectations for myself and the others I work with. So you will understand why I was quite rough. Anyway, I also want to encourage you in your work, do not give up no matter what(I am also a self-taught CFD user), but first get your hands on a Fluent doc and study it from start to end, page by page, and you will find out almost everything you need to know as a user. Further you will need to study a little bit of theory, can't do anything serious and most important CORRECT, without it. Best wishes, Razvan
Don't apologise - you helped me a lot. Actually it was funny to call me crazy
![]() Now back to SST k-omega. I hoped it will allow me to simulate BL transition on some barely measurable objects. But the result of the airfoil case is similar to the fully turbulent k-e simulation - i.e. very short laminar zone and the same drag. I woul like to delay transition distance more than 6 times boh in favourable and adverse pressure gradient zones. How to tune this model to better correspond to experimental results? Which k-omega constants to change? I am just beginning with turbulence math, so am not well oriented yet. |
Flat plate transition | RenardP | Main CFD Forum | 5 | April 8, 2010 01:07 |
Flat Plate Transition Test Case | Adam | CFX | 1 | June 23, 2005 23:12 |
Boundary layer transition over a flat plate | shraman | Main CFD Forum | 1 | May 12, 2005 04:55 |
'Fluent for Flat Plate Oscillatory BL Transition | Jay | FLUENT | 11 | July 11, 2002 05:48 |
2D Flat Plate Oscillatory BL Transition | Jayd | Main CFD Forum | 2 | June 18, 2002 08:02 |
