Anybody know the format of *.msh file?
Like Tree1Likes
  • 1 Post By jntan
Old   April 20, 2005, 05:19
Default Anybody know the format of *.msh file?
Vito Chow
I am developing my own code to do some simple computation, and i wanna read the *.msh file generated by Gambit. However, i have no idea of the file format. Could anybody here give me a hand? Any help will be appreciated.
Old   April 20, 2005, 05:32
Default Re: Anybody know the format of *.msh file?
Harish
create a simple rectangular 2-d geometry and make just few grid points. open the .msh file with wordpad and look at it.
-H
Old   April 20, 2005, 05:41
zxaar
fluent's manual describe the mesh format in section cas and data file formats (in the cas section you will have all the details you need).
Old   April 20, 2005, 09:11
rom
To get the basic grid informations select "generic" as solver type and export the neutral grid *.neu. Neutral mesh files are easy to unterstand even without the manual. they are devided into 3 sections: 1. a header with basic grid informations (number of nodes, number of elements,...); 2. the point coordinates and 3. the elements (wich points form a an element). if you added boundaries in gambit there will be an 4th section with boundary informations.
good luck rom
Old   April 20, 2005, 10:43
Vito Chow
actually i did it just as you suggested, but i failed to get the exact meaning of the file. it's a little bit troublesome.
the following is an example: a cavity with each edge divided into four parts, that is , nine cells.
(0 "GAMBIT to Fluent File")
(0 "Dimension:") (2 2)
(10 (0 1 10 1 2)) (10 (1 1 10 1 2)(
0.0000000000e+000 1.0000000000e+000
1.0000000000e+000 1.0000000000e+000
0.0000000000e+000 0.0000000000e+000
1.0000000000e+000 0.0000000000e+000
1.0000000000e+000 3.3333333333e-001
1.0000000000e+000 6.6666666667e-001
0.0000000000e+000 6.6666666667e-001
0.0000000000e+000 3.3333333333e-001
3.3333333333e-001 1.0000000000e+000
6.6666666667e-001 1.0000000000e+000
3.3333333333e-001 0.0000000000e+000
6.6666666667e-001 0.0000000000e+000
6.6666666667e-001 3.3333333333e-001
6.6666666667e-001 6.6666666667e-001
3.3333333333e-001 3.3333333333e-001
3.3333333333e-001 6.6666666667e-001 ))
(0 "Faces:") (13(0 1 18 0)) (13(3 1 9 3 0)( 2 1 7 9 0 2 7 8 6 0 2 8 3 3 0 2 3 b 3 0 2 b c 2 0 2 c 4 1 0 2 4 5 1 0 2 5 6 4 0 2 6 2 7 0 )) (13(4 a c 14 0)( 2 1 9 0 9 2 9 a 0 8 2 a 2 0 7 )) (13(6 d 18 2 0)( 2 d c 1 2 2 5 d 1 4 2 f b 2 3 2 d f 2 5 2 f 8 3 6 2 e d 4 5 2 6 e 4 7 2 10 f 5 6 2 e 10 5 8 2 10 7 6 9 2 a e 7 8 2 9 10 8 9 ))
(0 "Cells:") (12 (0 1 9 0)) (12 (2 1 9 1 3))
(0 "Zones:") (45 (2 fluid fluid)()) (45 (3 wall new_wall.4)()) (45 (4 mass-flow-inlet wall.4)()) (45 (6 interior default-interior)())
Old   April 20, 2005, 10:46
Vito Chow
i think i will try more to find it in the manual. thank you !
Old   April 20, 2005, 10:56
Vito Chow
compared to the *.msh, the *.neu file is easier to understand. But the problem is that some boundary conditions such as "wall","mass flow inlet", are not compatible with this filetype, so i cannot add the BC to the *.neu file, which make me turn to *.msh file.
Old   May 12, 2010, 13:01
Jiannan
jntan is on a distinguished road
The structure of *.msh file is closely related to FLUENT solver. Although you can easily open the file with a wordpad something and extract the point information, only point information is far from enough to be utilized in a solver. You need more information on how these points are connected and how the volume cells are built.
I spent more than 1 year looking into the *.msh file structure and finally figured it out. Then I built my own solver for research purpose on that. Drop me a message if you are interested in more details.
cheers,
febriyan91 likes this.
jntan is offline   Reply With Quote
Old   November 27, 2010, 15:49
Okke Bronkhorst
Okke79 is on a distinguished road
Dear jntan,
I am very interested in more details about reading the *.msh file.
Regards,
Okke
Okke79 is offline   Reply With Quote
Old   October 16, 2014, 14:17
k
znri is on a distinguished road
cheers,
I need to edit my msh file manually. Can you please tell me how can I start to find the structure of fluent msh files?
Best regards
znri is offline   Reply With Quote
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 08:11
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 16:49
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
