April 4, 2005, 12:06 |
UDF and Number iterations
Hello, I would like to change viscosity all the 1000 iterations by UDF but I do not know the variable of the number iteration. Can you show me the variable of the number iterations. Thank you!
April 7, 2005, 05:05 |
Re: UDF and Number iterations
you can define a global variable
int It_Number=0; and in a define_adjust function to increase this variable. Thus you can verify the number of iterations and change the viscosity value. |
June 14, 2021, 07:17 |
change de mass source from an udf each 100 iteration
Beatriz
Rep Power: 5 |
I read this post and I would like to do the same. Update a mass source value each 100 iterations. I have an udf that call a fortran program that calculates the mass source value. So, to define the number of iterations, do I need a second udf? Or can I use DEFINE_ADJUST inside the DEFINE_SOURCE? Thanks in advance! |
complex number operation in udf? | hongxiao | FLUENT | 5 | June 14, 2017 14:11 |
How to get the Global Node Number by UDF : Fluent | Yusuke | FLUENT | 1 | October 23, 2015 10:55 |
Help with UDF - nusselt number | Sammie | FLUENT | 0 | October 24, 2007 07:10 |
Nusselt number in UDF | Manuel | FLUENT | 0 | November 6, 2006 07:23 |
Change Courant number from UDF | HS | FLUENT | 0 | December 1, 2005 05:16 |
