Turbulence Specification Method
Like Tree1Likes
  • 1 Post By ROOZBEH
Old   March 16, 2005, 15:48
Default Turbulence Specification Method
Srivatsan V. Rajagopalan
I am using a K-Epsilon turbulence modelling for simulatig a supersonic compreeible turbulent flow in a nozzle. Can anyone pls tell me what to specify in "Turbulence Specification Method" in the "inlet panel" of Boundary conditions?
The Help in Fluent uses a "Intensity and Hydraulic Diameter" Can any one explaain me why it is so?
Srivatsan
Old   March 17, 2005, 05:11
Default Re: Turbulence Specification Method
ROOZBEH
Hi; You must set values as boundary condition for turbulence model equations, for example "k and e equations". You should set a value for k and a value for epsilon. But it is very difficult for a user to know what value is better to set. Instead, you can set values for turbulence intensity and viscosity ratio or hydrolic diameter. Fluent uses these values for boundary conditions. ROOZBEH
palmerlee likes this.
Old   March 17, 2005, 12:49
HI Roozbez! Thanks for your suggstion. As mentioned by U, I use only Hydraulic diameter. Can U pls take a little time in eplaining me how to define Viscosity ratio? It depends on what? Thnk you in advance!
Old   April 4, 2005, 01:50
mahmoud
Old   May 20, 2009, 21:24
Smile Hydraulic Diameter
mahadevan.swamy@gmail.com
mahadevan.swamy is on a distinguished road
I am making a 2D case analysis by have a 2D body in a tunnel (plane). I don't know how to find the hydraulic diameter or the length scale of this problem. I do know that the air will be travelling at 27.76 m/s around the body. How do I calculate the hydraulic diameter for this 2D case? Any ideas? Thanks in advance
Swamy
mahadevan.swamy is offline   Reply With Quote
Old   January 31, 2011, 07:39
shaoda169 is on a distinguished road
Originally Posted by mahadevan.swamy View Post
Swamy
please refer to this website. http://support.esi-cfd.com/esi-users/turb_parameters/
shaoda169 is offline   Reply With Quote
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 05:30
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
question about Turbulence Specification in Starccm Wei Siemens 2 February 2, 2009 05:14
Turbulence models for GCV method dosen't work! Sima Baheri Phoenics 0 January 6, 2007 05:08
Turbulence boundary values lego Main CFD Forum 0 October 24, 2002 14:47
