How to create a circular surface?
Like Tree1Likes
  • 1 Post By pakk
Old   March 7, 2005, 16:25
Default How to create a circular surface?
Jen
When i choose bounded surface in surface/plan, I just can create bounded rectangular surface. How can I create a bounded circular surface?
Thanks,
Jen
Old   March 7, 2005, 20:33
Default Re: How to create a circular surface?
zxaar
create a volume that has this circular surface you want , split this volume by the rect surfaces u have created, copy the circular surface and delete the volume,
Old   March 8, 2005, 00:11
Tang
You cannot create circular surfaces. I have addressed this to fluent tech support to create a circular plane tool or a circular plane creation button in the surface/plane menu. Perhaps in a future version.
Old   March 8, 2005, 15:23
Jen
so disappointing~ sigh~
Jen
in FLUENT, not in GAMBIT
Old   March 8, 2005, 20:01
zxaar
sorry ..i just din't read it properly ..my mistake
Old   December 7, 2020, 11:57
Anil Kumar B
anijg05 is on a distinguished road
Hope you got answer! if not,
Try 'iso-surface'.
Before that, define in 'Custom field function calculator' sqrt(x^2 + y^2) (It doesn't have to be x&y, check in which plane you want)
Then using the above defined field as 'surface of constant' in iso-surface
Prescribe the required radius in 'Iso-values'
Then Enter!
Bingo!
anijg05 is offline   Reply With Quote
Old   December 7, 2020, 14:09
pakk will become famous soon enough
I don't think that worked in 2005.
manahara likes this.
pakk is offline   Reply With Quote
How to create a free surface application in Openfoam ? phuchuynh OpenFOAM 28 September 21, 2011 04:35
Create a surface inside a volume Michael CFX 1 February 4, 2009 17:42
how to create contour surface for some range sa CFX 6 January 28, 2009 15:36
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 14:43
