How to plot interface shape between two phases.
Like Tree1Likes
  • 1 Post By pavel
Old   March 1, 2005, 15:35
Default How to plot interface shape between two phases.
Manoj Kumar
hi everone
Can anyone help me to plot the shape of interface between two phases. I have solved my problem using VOF scheme ( with 2 phases, air and water). Now i want to plot the shape of free surface, as well as the contour of water height with respect to initial water surface.
Please help. Thanking u..
Manoj
Old   March 1, 2005, 17:27
Default Re: How to plot interface shape between two phases
James
I think you need to export boths data by ASCII data. Then, use another plot tools such as MatLab or TecPlot. ex, for MatLab 1. Plot initail water 2. hold on 3. Plot water height.
Is it an answer?
Old   March 2, 2005, 04:53
Manoj Kumar
Thanx James. I am going to try this now.
Old   March 2, 2005, 10:10
Amir
FLUENT have a specific postprocessing feature for that.
Solve -> Animate -> Define In "Define" choose water volume fracion
Old   March 3, 2005, 13:25
Manoj Kumar
Hi Amir I am using steady state scheme and have got the final data after iteration. I am able to plot contours of volume fraction of water on any plane in the domain, by using swape surface feature. But how do I plot the actual deformed free surface. Is there any such feature in fluent.
Thanks
Old   March 3, 2005, 13:38
pavel
Hi ...
You can plot the surface shape using the iso-surface tool in the surface menu. Once you are in the iso-surface menu, choose volume fraction option (obviously you are working with the VOF model!),choose the phase you want to analyse, and type 0.5 as constant value. Finally, go to the grid menu and select the iso-surface you have created. For better presentation, go to the options and turn the lights on.
If you want to trace the surface in transient case, you must save the data for the initial and final step you want to visualize.
Hope this should be useful.
Bye
Rajkool likes this.
Old   March 3, 2005, 16:47
Manoj Kumar
hi Pavel Thanks a lot. I tried it and it worked so well. Thanks again. Manoj
Old   May 10, 2017, 04:31
Johanna
JohannaC is on a distinguished road
I'm new in simulations and now i'm stucking on a similar problem. I was able to plot the contour of the volume fraction in Fluent-Post at a certrain time step, but I need to export the geometry data at this time-step (transient simulation) to import it later into Matlab.
Do I have to write a macro?
JohannaC is offline   Reply With Quote
Old   April 1, 2020, 08:13
Raj
Rajkool is on a distinguished road
Hello Pavel,
I have the same case and I think your answer would be useful.
But, my case is a bit different. I am using steady and transient in a single calculation because both the cases are present in my model.
Please let me know, do you have any other suggestions.
Thank you
Raj
Rajkool is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
plotting all phases in a single plot Maziar Mahzari FLUENT 0 January 10, 2006 05:29
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
