Aircraft propeller simulation
Like Tree2Likes
  • 1 Post By white
  • 1 Post By cip
Old   February 4, 2005, 05:52
Default Aircraft propeller simulation
white
Hello. I'm going to simulate a 3 and 4 bladed aircraft propeller encountered with side flow. Can anybody out there help me to get some idea to simulate this propeller? I've used MRF before, however I got negative lift result. For your information, Fluent 6.1 was used to simulate this propeller?
M MOHSIN likes this.
Old   February 14, 2005, 12:16
Default Re: Aircraft propeller simulation
cip
yes you can do it very simple. once you have the geometry all you have to do is to put your propeller into a cilinder and give a rotation mouvement to the reference. in the tutorials you can find a model for rotor stator flow. is the same thing only that your rotor is the propeler and the stator is the plane. yes i've done a hovercraft propeler in fluent and those ware happy with the results
cip
Old   January 13, 2014, 05:20
M MOHSIN's Avatar
M Mohsin Iqbal
Location: National University Sciencies & Technology, Pakistan
M MOHSIN is on a distinguished road
Hi . i want to do propeller simulation in CFD and then extract results like
VORTEX INTERACTION
THRUST DISTRIBUTION
PRESSURE DISTRIBUTION
VELOCITY CONTOURS etc
So plz guide me how can i do it i.e Meshing type ?? boundary conditions in FLUENT ???? .
REGARDS
Pro-engineer
you can email me also sir at twinklingbeacon@gmail.com
M MOHSIN is offline   Reply With Quote
Old   January 4, 2016, 03:14
samrat himvanth nanduri
samcfd is on a distinguished road
hi ,
im working on a simulation of a helicopter propeller in FLUENT, I would want to understand what is the kind of mesh domain that is most suitable for this kind of a problem...also can u please help me as in how to set up the model in fluent...What kind of technique is being used for rotating elements and how to set up the problem..Thanks a ton...
samcfd is offline   Reply With Quote
Quadrotor helicopter propeller simulation Attesz CFX 14 December 4, 2017 16:45
Propeller Simulation Craig Paxton FLUENT 11 February 17, 2010 00:57
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 14:46
3D aircraft simulation harrislcy FLUENT 1 November 11, 2009 13:31
Propeller flow simulation jun005 Main CFD Forum 0 August 5, 2009 03:10
