Particle size in Eulerian Multiphase Model.
Like Tree1Likes
  • 1 Post By jwwang
Old   January 1, 2005, 06:56
Default Particle size in Eulerian Multiphase Model.
guru
I am using a Eulerian-Eulerian Multiphase model to simulate the Oil separation from the Air.
Any "clue / guidelines" to choose the Secondary phase Oil particle Diameter size, for Phase definition? (Volume fraction of Oil varies from 3 to 11 %)
Thanks in advance. Guru.
Old   January 4, 2005, 04:51
Default Re: Particle size in Eulerian Multiphase Model.
fpingqian
You can see the manual. I think you can select the oil as the secondary phase. However, in Eulerian-Eulerian Multiphase model , you only can set one diameter size, not a diameter size distribution.
Old   January 10, 2005, 06:01
jwwang
you can use the udf! #include udf.h
DEFINE_PROFILE(particel_distribution,thread,index) {
real x[ND_ND]; real y; cell_t c;
begin_c_loop(c,thread)
{ C_CENTROID(x,c,thread); y=x[1]; F_PROFILE(c,thread,index)=1(exp(pow(y16,1.2))); } end_c_loop(c,thread) }
mdzaaibt likes this.
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
Particle Transport Using the Eulerian Model Converge please! FLUENT 2 February 24, 2010 06:14
A model is used to model particle interaction with the geometry dungsidietquy FLUENT 0 November 4, 2009 17:05
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 11, 2007 00:23
Selecting the multiphase model lily FLUENT 4 August 4, 2005 04:40
