Porous jump & Porous zone - help needed
Like Tree2Likes
  • 2 Post By Prakash Verma
Old   December 28, 2004, 00:15
Default Porous jump & Porous zone - help needed
Witsarut Jintaworn
I have some problem. My system is use the ceramic filter as porous media (3D as thickness 1.5 cm). How can i choose between porous jump and porous zone or i have to use it both? I try to read the user guide but it's not clear. Could anybody help me please.
Old   December 28, 2004, 03:42
Default Re: Porous jump & Porous zone - help needed
Prakash Verma
Porous jump model is used in face zone not in cell zone so use porous zone because your geometry is 3D. First define your zone as fluid and then in boundary condition add the porous zone by setting the inertial and viscous resistance coefficients. You can find how to calculate these coefficients in the help manual. Define the porosity also. Or you can use power law model. For more detail use the manual. hope it will be helpful for you.
-Prakash
DungPham and kevin_mst like this.
Old   December 28, 2004, 04:57
Witsarut Jintaworn
Thank you very much for your suggestion. I'll try to do this.
Old   June 14, 2010, 23:37
xudiyi
diyi.xu is on a distinguished road
I have a question. In this case, how what should I set as boundary conditions for the four edges of my porous zone in Gambit and Fluent since apparently I can not set them as porous jump at the same time and I don't think there are interfaces either?
Thanks!
diyi.xu is offline   Reply With Quote
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 05:10
Porous zone boundary condition- help needed Shankar FLUENT 12 March 22, 2012 07:44
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
Porous jump V.S Porous zone phxfudong FLUENT 1 October 8, 2009 23:11
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
