Mixing Plane
Like Tree2Likes
  • 1 Post By emre
  • 1 Post By emre
Old   December 23, 2004, 23:53
Default Mixing Plane
Ellen
hi, all;
My project is about airconditioning outdoor unit modeling which include a propeller fan . I want to use mixing plane model. Since our target is to calculate CFM , which boundary condition should I use for downstream, Mass flow inlet or pressure inlet?
If I use mass flow inlet , then How to specify the average mass flux for mass flow inlet?
thanks for attention
Old   December 26, 2004, 12:26
Default Re: Mixing Plane
emre
If youre going to model the whole AC unit, model the fan as lumped, by specifying its P-V curve if you know it. If you just have the geometry but no curve, then model it with MRF not MPM. Use pressure inlet and pressure outlet BCs.
Regards, Emre
granzer likes this.
Old   December 27, 2004, 23:28
Ellen
Hi,Emre:
Thanks for your kindly help!
In fact, I only have used the MRF with pressure inlet/outlet boundary condition. The reason I want to use Mixing plane is to see whether the results can be improved. Could you elaborate on why I can't choose MPM if fan curve is unknown.
Regards,
Ellen
Old   December 28, 2004, 04:04
emre
Hi Ellen,
In order to improve your results you could use sliding mesh model, which is computationally more expensive since you have to solve unsteady flow. I have seen applications of MPM only for rotor-stator interactions.
Best Regards,
Emre
granzer likes this.
mixing plane model: too much backflow and does not converge sbhi FLUENT 1 December 4, 2014 01:31
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 15:31
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 10:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 18:08
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 08:16
