User Defined Non Reflecting Boundary Condition |
November 17, 2004, 06:55 |
HI folks
I simulate a case with a shockwave in water. With 6.2.5 segregated solver (the new solution from fluent) or a udf-based 6.1.22 coupled imp solution. In both the problem is 2d, dp, compressible, unsteady. All shockwaves reflecting at the pressure-outlet boundary. Now I need to programm a NRBC (nonreflecting-BC) with UDF. My idea is that I read the Face-Pressure out in every BC-Face, invert it and write back to clean the reflection. I just need to see what happen in the closed case and each wave which leaves the boundary should not get reflected. Thx for ur ideas Christian Tenger, Fachhochschule Biel Schweiz |
November 17, 2004, 14:58 |
Re: User Defined Non Reflecting Boundary Condition
A simple question...how can you set the value of the pressure you want? i'm really interested the way you do it. thanks Luca
November 9, 2021, 05:18 |
Sanda
Rep Power: 5 |
Dear Tengc,
Did you able to solve it? If you got the udf, can you please share it? |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Display boundary condition defined by UDFs | trantoan2008 | Fluent UDF and Scheme Programming | 8 | February 21, 2011 07:24 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 13:26 |
Boundary condition using user subroutine | wei | Siemens | 0 | July 6, 2009 11:47 |
Partially reflecting boundary condition | Rachel | FLUENT | 1 | July 1, 2008 19:20 |
