UDF for source term in momentum equation
Like Tree2Likes
  • 1 Post By Enrico
  • 1 Post By Bowling
Old   November 4, 2004, 05:50
Default UDF for source term in momentum equation
Enrico
Hi all I write a UDF for source term in momentum equation this source term is : A.( du/dx) , where u is the x-component of the velocity ...
please can somebody tell me what is the mistacke I have do in this UDF
DEFINE_SOURCE(xmom_source, c, t, dS, eqn) {
real source;
source = A*C_DUDX(c,t);
return source; }
Chakra likes this.
Old   November 4, 2004, 06:50
Default Re: UDF for source term in momentum equation
Andrew Garrard
you haven't defined A?
Old   November 5, 2004, 04:26
Sun
Not only that you have not defined A, but also you have to add one more statement namely:
dS[eqn]=0;
Good Luck to you. Sun
Old   November 6, 2004, 05:26
enrico
A is a constant
Old   November 9, 2004, 05:27
Bowling
Yes, A is a constant but you must define it. for example; DEFINE_SOURCE(xmom_source, c, t, dS, eqn) { real source; int A; A=22; source = A*C_DUDX(c,t); dS[eqn]=0;
return source; }
"A" can be real or integer. It is up to you.
Hope I can help you. Bowling
Old   November 10, 2004, 07:06
enrico
Hi ,Bowling , but why dS[eqn]=0 ? dS[eqn]=dS/dU
Old   November 12, 2004, 01:58
Bowling
You are misunderstand. dS[eqn] in here means d(source)/d(your parameter) eg. x-momentum, your parameter is U your source is A*(dU/dX), so dS[eqn] is second derivative of dU/dX equal d^2U/dX^2. Diff your source by your parameter.
dS[eqn] is the way to define your source solving. I don't know how to explain. You can read more infomation in fluent document.
Bowling
Old   November 13, 2004, 04:33
enrico
Hi Bowling , should i use UDS for calculating dS[eqn] ?
Old   November 15, 2004, 01:20
Bowling
I don't think so. It is the condition in DEFINE_SOURCE. It is the way to solve in the finite volume method not a scalar.
Bowling
Rashed likes this.
Old   May 30, 2014, 12:34
itsme_kit is on a distinguished road
how do we know this formula: source = A*C_DUDX(c,t);
I have a equation for velocity gradient: dudz=const
However, I have no idea how to transfer my equation into this kind of form: source = A*C_DUDX(c,t);
Thanks
itsme_kit is offline   Reply With Quote
add source term to energy equation by udf tomas Fluent UDF and Scheme Programming 7 September 10, 2013 03:08
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 20:53
UDF Time-dependent term in source Ronnfors FLUENT 0 October 16, 2009 12:25
UDF Source Term Units? Brian FLUENT 1 October 24, 2005 10:15
bouyancy term in epsilon equation Michael Main CFD Forum 1 June 25, 1999 11:20
