2D Large Eddy Simulation with fluent?
Like Tree2Likes
  • 2 Post By pitamber.methia
Old   June 21, 2004, 02:12
Default 2D Large Eddy Simulation with fluent?
Barry Cole
Hi Can fluent solve the 2d Flitered NS (Large Eddy Simulation) equations?
Also if fluent doesn't offer 2d LES capablitites can anyone sutggest a COMERCIAL code that does.
Thanks in advance
Old   June 21, 2004, 03:36
Default Re: 2D Large Eddy Simulation with fluent?
Jonas Larsson
Yes, fluent can run the LES model in 2D. However, it doesn't make much sence to do this. LES = Large Eddy Simulation = resolving the large scale turbulent eddies. These large-scale turbulent eddies are 3D by nature and if you run 2D you will not resolve them. Hence, a 2D LES simulation is not going to produce anything physical. It is just a numerical exercise that you might want to do to debug your code or something.
Old   June 21, 2004, 03:39
Barry Cole
Ok Thanks
Old   April 26, 2011, 10:43
Default Les-2d
anil_samale is on a distinguished road
Hi Jonhson,
As if you say running LES for 2D is just an numerical excersize then while soving flow over cylinder by LES Model gives different results than K-epsilon.. I means LES model gives close results...though large eddies are absent or 3d in nature....can you please give some idea of same. Since I am trying to solve flow over cylinder...
anil_samale is offline   Reply With Quote
Old   October 2, 2013, 14:36
PSM
pitamber.methia is on a distinguished road
use command (rpsetvar 'les-2d? #t)
LES will come in models option
LES is used for axis-symmetric geometries only
mm.abdollahzadeh and bairagi like this.
pitamber.methia is offline   Reply With Quote
wall function in large eddy simulation siamak1424 FLUENT 0 November 22, 2009 10:51
Fluent Remote Simulation Facility Service (RSF) di Rami FLUENT 2 June 4, 2008 06:38
Large Eddy Simulation Shamoon FLUENT 0 April 20, 2008 03:39
Large eddy simulation David FLUENT 1 December 11, 2006 13:18
help for Large eddy simulation Randheer Yadav FLUENT 0 July 27, 2005 17:38
