segregated flow solver
Like Tree2Likes
  • 1 Post By sania
  • 1 Post By Mukkarum
Old   June 10, 2004, 17:12
Default segregated flow solver
sania
please tell me what is meant by segregated flow solver.how it differs from coupled solver. thanks sania
nabidinhomessi likes this.
Old   June 11, 2004, 03:11
Default Re: segregated flow solver
Mukkarum
Assalam Alaykum wa Rahmatullah
Dear Madam
The segregated solver is the solution algorithm previously used by FLUENT 4. Using this approach, the governing equations are solved sequentially (i.e., segregated from one another). Because the governing equations are non-linear (and coupled), several iterations of the solution loop must be performed before a converged solution is obtained.
The coupled solver solves the governing equations of continuity, momentum, and (where appropriate) energy and species transport simultaneously (i.e., coupled together). Governing equations for additional scalars will be solved sequentially (i.e., segregated from one another and from the coupled set.
Hope this Help. You should see the chapter 24 of Fluent's Manual.
Wasalam Mukkarum
mohammad likes this.
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 12:34
Coupled and Segregated solver soe FLUENT 2 March 8, 2007 05:37
Convergence Definition of Segregated Solver Amir FLUENT 0 April 18, 2006 07:21
Inviscid solver : separation of the flow Jean-Marie Cavet FLUENT 1 September 2, 2003 13:32
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
