DPM: Particle tracks stop at a "reflect" surface
Like Tree1Likes
  • 1 Post By Confused
Old   April 16, 2004, 16:45
Default DPM: Particle tracks stop at a "reflect" surface
Confused
I have an unbaffled stirred tank reactor with a shaft and paddle rotating at 200 rpm. I have used MRF and realizable k-e to get a steady state solution. I have then used the discrete phase model to track a single particle dropped onto the free surface of the liquid. I have set the number of steps to 3x10^6 and the step length factor to 20. There are no inlets or outlets. I get a calculated residence time of approx 45s. However, when I view the particle track, I see the particle descending through the fluid in a circular fashion around the shaft until it hits the face of the paddle. When it hits the impeller it just stops as if it is trapped. This is confusing because in the Define-Boundary Conditions box, all walls are set to reflect and so is the impeller and the shaft. The impeller is stationary and the fluid is rotating (as I said, I have modelled using MRF).
Does anyone have any idea why this is happening? It's driving me completely mad!!! Any and all ideas gratefully received.
Arjun kumar P likes this.
Old   May 10, 2004, 11:36
Default Re: DPM: Particle tracks stop at a "reflect" surfa
zachi
are u using stochastic tracking?
regards
zachi!
Old   May 11, 2004, 14:31
mantaray
i use stochastic tracking.
check the wall reflection coefficients in the wall boundary conditions panel. if they are zero it would cause particles to stop.
Old   February 7, 2022, 13:12
P Arjun kumar
Arjun kumar P is on a distinguished road
Hi, I am also facing similar situation. Can you tell me how did you circumvent this challenge. Particles sticking to the wall!!
Arjun kumar P is offline   Reply With Quote
unsteady DPM particle tracks animation Don Parsons FLUENT 5 March 2, 2016 03:52
DPM particle tracking in stirred tank parisa- FLUENT 1 August 7, 2012 13:03
Particle tracks stop? MG Siemens 7 December 3, 2004 12:01
Particle Tracks Ram FLUENT 2 January 25, 2003 12:08
Particle tracks Sridhar FLUENT 0 October 5, 2002 13:19
