What type of boundary for a moving rigid body?
Like Tree1Likes
  • 1 Post By Ryan
Old   April 12, 2004, 05:21
Default What type of boundary for a moving rigid body?
Ryan
A rigid body moves upward vertically inside water at a constant velocity. Dynamic mesh is used in this situation. But I wonder which type of boundary is suitable to define this rigid body, wall type or other types?
many thanks.
kimhodang likes this.
Old   April 13, 2004, 05:50
Default Re: What type of boundary for a moving rigid body?
emma
You can define it as wall in Gambit or any other preprocessors of fluent. In the calculation with fluent, you need to choose the motion type of this wall e.g. UDF, boundary profile, and other items about the correspondent motion type.
Hope it helps.
Emma
Old   April 13, 2004, 06:21
Ryan
Thanks, emma
I use a rectangle to stand for this 2D rigid body. And it moves up vertically. There are four edges. Should I define all of them as the type of rigid body in Dynamic Zone panel? or define the top edge and bottom edge as rigid body, left and right edge as the type of deforming in the panel?
Best wishes!
Old   April 13, 2004, 06:58
emma
For the vertically up-moving edge, it should be defined as rigid body, the two edges which are next to it could be defined as deforming. Another edge, if it doesn's move, is unnecessary to be defined in the dynamic mesh zone panel.
Best luck!
Emma
Old   April 13, 2004, 09:39
Ryan
In fact, all of the four edges move. Why can not make all these four edges as a face zone and define this face zone as rigid body?
Thanks. Best wishes.
Old   April 13, 2004, 12:55
emma
Sure, you can define the four edges as a face zone and describe the motion type as regid body!
Emma
second order schemes marine OpenFOAM 67 April 11, 2022 19:19
Free jet simulation msarkar OpenFOAM Running, Solving & CFD 39 May 11, 2021 14:21
Boundary condition setting for non-premixed combustion using reactingFoam skyopener OpenFOAM 0 May 23, 2010 23:55
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Flow Around a Cylinder ronaldo OpenFOAM 5 September 18, 2009 09:13
