printing values from udf!!!
Like Tree7Likes
  • 1 Post By Shekhar
  • 6 Post By ap
Old   January 13, 2004, 05:50
Default printing values from udf!!!
Shekhar
how can i print the values returned by an udf in the fluent console window.....i want to check whether my udf is giving the correct values or not... hi shekhar
Lucrecio likes this.
Old   January 13, 2004, 10:16
Default Re: printing values from udf!!!
Manoj
you can write in your udf the printf statement as you do in C programming. it will print whatever values you want.
Old   January 13, 2004, 12:49
ap
You can use the command:
Message ("Text %g \n", var_name);
where:
- Text is a string.
- %g is the placeholder where the value of the variable var_name will be written. %g is for real values, if you want to write an integer (int) value, use %d.
- \n is the new line command.
For example, if you want to write two variables i (int) and s (real), viewing something like this in the console:
"The value of i is 9 and the value of s is 3.5."
you have to write the command:
Message("The value of i is %d and the value of s is %g\n",i,s);
Hi
ap
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 08:11
Accessing node values using a UDF Nico FLUENT 2 December 20, 2007 03:50
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
udf language + UDMI values chary FLUENT 0 October 5, 2007 07:58
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
