Error: unbound variable
Like Tree5Likes
  • 3 Post By David
  • 2 Post By eric
Old   November 1, 2003, 06:18
Default Error: unbound variable
eric
When i open my mesh file, from gambit, in fluent for the first time i get the following error message
Error: access: unbound variable Error Object: phase-domain?
What does this mean and will it affect the results? The grid check is fine.
Regards
Eric
Old   November 3, 2003, 07:53
Default Re: Error: unbound variable
David
hi,
was your problem finally solved?
you said earlier:
It has to do with how you name your boundaries. For example they should be named inlet_1 or inlet-1 and not inlet 1. A character space causes the problem.
did it work or not?
let us know
David
Old   November 3, 2003, 11:22
eric
Hi David,
Yes it did.
I had an inlet named "inlet 1", and when i originally opened the file in fluent i got the error message.
I then went back into gambit and changed the name to "inlet_1" and the error message dissappeared.
A simple error which probably has no effect on the simulation
Eric
clivemathe and mahmoud.alaa like this.
Old   November 12, 2019, 10:37
Default Error: access: unbound variable Error Object: active?
Chien Chih Lin
Jerry0224 is on a distinguished road
hi :
I am using Mesh Morpher, I create two control point distribution. However, after updating the Fluent, I receive the error "Error: access: unbound variable Error Object: active? "
Can anyone help me?
Jerry0224 is offline   Reply With Quote
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
Problems with additional variable Krishna Premi CFX 1 October 29, 2007 09:19
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
