LES Tutorial using fluent
Like Tree1Likes
  • 1 Post By LuckyTran
Old   September 19, 2003, 06:53
Default LES Tutorial using fluent
anindya
Is there any LES tutorial using FLUENT ?
Thanks
Anindya
Old   September 25, 2003, 06:05
Default Re: LES Tutorial using fluent
Chetan Kadakia
There is. Fluent has an acoustic model where LES is used with flow over a cylinder.
Why do you need a tutorial using Fluent? LES requires a fine mesh and small time step. Other than that, just select the LES and run it.
What are you trying to accomplish? How can I help you?
Old   September 25, 2003, 12:36
anindya
I am trying to simulate an impinging jet flow using LES. I would like to see the jet coming out of the nozzle and then hitting the ground plane. I would also like to see how the wall jet then develop and the boundary layer profile at various r/D distances on the ground surface.
I am also trying to see how the ground pressures change if instead of having a stationary jet, the jet nozzle is moving at some velocity v relative to the ground plane.
How can I do that? Can you give me some insight to modeling these?
Old   October 14, 2016, 05:03
raunak jung pandey
raunakjung is on a distinguished road
Are inlet conditions different for LES ?
raunakjung is offline   Reply With Quote
Old   October 14, 2016, 11:38
Lucky
You need time-accurate inlet boundary conditions for LES. That is, you "cannot" just specify the time-averaged mean flow quantities, you need to specify the instantaneous quantities. You can use like the synthetic vortices like the spectral synthesizer if needed to generate the instantaneous quantities from time-averaged quantities. But philosophically, the need for time-accurate inlet conditions is what makes LES harder than RANS.
Old   October 16, 2016, 02:17
raunak jung pandey
I see use of TUI COMMAND /solve/initialize/init-instantaneous-vel
to superimpose the synthesized turbulence on the mean flow. Is this practice appropriate to generate instantaneous velocity ?
Old   October 16, 2016, 04:16
Lucky
That tool is for generating initial conditions for LES from RANS or mean-flow data. It is for perturbing the mean flow to give it some synthetic turbulence or else the LES will stay laminar. Its usable for generating instantaneous velocity for the initial conditions but you still need boundary conditions!
mghr likes this.
Old   October 17, 2016, 10:17
Zbynek is on a distinguished road
It is pretty much as LuckyTran said. If you have a system that does not contain any inlets and you have a converged RANS solution of the system available, you can switch to LES and let the flow field develop over time till it reaches a pseudo-steady state. The utility /solve/initialize/init-instantaneous-vel is useful in the sense that it introduces a perturbation to the RANS solution and so you should achieve the pseudo-steady state earlier. However, if an inlet is present in the system, you surely need a way how to perturb the inlet condition. Fluent gives you two options, I think - spectral syntesizer and vortex method.
Zbynek is offline   Reply With Quote
IC engine simulation tutorial by FLUENT yash FLUENT 4 April 6, 2015 20:44
LES and near wall treatment approach in Fluent khosro1355 Main CFD Forum 1 July 10, 2009 11:49
IC engine simulation tutorial by FLUENT yash Main CFD Forum 1 April 21, 2009 06:05
Request for pipe bifurcation fluent tutorial case Giorgos Momferratos FLUENT 0 October 20, 2008 16:10
FDS vs Fluent, what's the difference on LES? Jim FLUENT 0 August 12, 2006 16:32
