contour plot of stream function
Like Tree1Likes
  • 1 Post By Jonas Larsson
Old   August 19, 2003, 14:06
Default contour plot of stream function
liu
In contour display, I could not find contour plot for stream function-streamline. Do I have to define it by myself? what should I do if I want to plot streamline? Thank you.
Old   August 19, 2003, 14:35
Default Re: contour plot of stream function
Jason
display->contour->velocity->streamline
Old   August 19, 2003, 15:00
liu
Thank you. But I still could not find "streamline" under "contours of veloctiy". I am using Fluent 6.0. There are velocity magnitude, X, Y, Z velocities, tangential velocity, vorticity, and so on. Can you tell me why.
Old   August 19, 2003, 15:17
Jonas Larsson
Contours of streamfunction is only available in 2D. In 3D your best solution is to plot path-lines released from an appropriate surface, line or point.
majid fahim likes this.
Old   August 19, 2003, 15:32
Jason
I have Fluent6.0. It has stream function under velocity. I'm not sure of your case
Old   August 19, 2003, 18:13
liu
Thanks, Jonas. My case is 3-D problem and your suggestion is helpful. Jason, I appreciate your response. Now I understood it.
Old   August 19, 2003, 23:30
Chen Fangzhi
for 2d and 3d, there is slight difference.
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 09:53
to plot Mach contour using GNUPLOT killtimm Main CFD Forum 2 December 28, 2009 12:15
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
PLOT STREAM FUNCTION ON 3D??????????????? naus FLUENT 3 April 26, 2006 08:30
HELP - stream function from the velocity field Fred Main CFD Forum 10 January 26, 1999 13:58
