Variation in volume fraction
Like Tree1Likes
  • 1 Post By Pravesh Kumar
Old   August 5, 2003, 11:52
Default Variation in volume fraction
Pravesh Kumar
hi I want to fix the different volume fraction at differnt locations in domain.Actually my problem is liquid and gas flow through solid(stationary) which are having different fraction in the domain.Can somebody tell how I can assign different volume fraction at different locations as my domain is divided in more than 1000 parts each having different volume fraction.
Help urgently required
Thanks
Zahid Ibrahim likes this.
Old   August 6, 2003, 09:03
Default Re: Variation in volume fraction
mateus
Hi!
One way to do it is to: Adapt-Region....here you define regions of interest and give them names. Then go to Solve-initialize-patch and attach desired value of volume fraction to the desired region. You can read about it in fluent documentation tutorial for Vof model.... Since you have many regions of interest you are looking at a loooooooong process...maybe there is an easier way to do it?????
Regards
MATEUS
Old   August 6, 2003, 11:27
Pravesh Kumar
Thanks for the reply. Yes you are right To patch 1000 regions is one by one is not possible.Can you suggest some other way . Can UDF can be used.Then how?
With best wishes.
Pravesh
Old   August 25, 2003, 11:51
Adel
Hi, there are another possibility to batch the 100 region! You may devide the regions into small volumes! Every volume represents the cells you need to batch to one value of VOF, but you need here to define all the internal surfaces as interiors! It takes very long time but I think it is better than the Adaption Method! best wishes Adel
Old   August 26, 2003, 05:08
Pravesh Kumar
The problem remains same whether I divide the domain into different regions or adapt the differnet region.It is always going to be tedious to patch such a large no of volumes separately and if volumes are grater than 100?
Regards
Pravesh
Old   November 6, 2013, 01:48
Zahid Ibrahim Mohammed
Zahid Ibrahim is on a distinguished road
Originally Posted by Pravesh Kumar
;107312
Thanks
Hi I'm new in use (cfx-14) I want the different volume fraction. Actually my problem is water and air flow through straight pipe. Can somebody tell how I can get the lower half of pipe fill in water and the upper half fill in air.
Thanks
Zahid Ibrahim is offline   Reply With Quote
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
