How to get the wall shear stress by UDF
Like Tree1Likes
  • 1 Post By Chen Fangzhi
Old   June 24, 2003, 13:13
Default How to get the wall shear stress by UDF
Chen Fangzhi
I need the value of wall shear stress of the first cell close to a wall and use it to get the friction velocity by UDF. Is there any Macro available to do this? Also, is it possible to get the yplus of a cell near a wall (not necessary the first cell to the wall)?
Thanks a lot!!!
Old   June 24, 2003, 13:17
Default Re: How to get the wall shear stress by UDF
Chen Fangzhi
The flow is turbulent and I use the RSM model.I want to fix the normal Reynolds stress component as an empirical function of y+. It is important to get the value of y+ or wall shear stress from which to get y +.
Quasar_89 likes this.
Old   May 21, 2010, 10:32
Hanz is on a distinguished road
I know the post was a while ago.
Did you find out how to access the wall shear stress using a UDF ?
Hanz is offline   Reply With Quote
Old   November 11, 2014, 07:03
Default hi
Qureshi M Z I
m zahid is on a distinguished road
hi, have u find the answer please share this, i want to calculate the wall shear and y plus at first node height and also the reynold number
thanks
m zahid is offline   Reply With Quote
UDF for shear stress at wall in laminar flow Jafri FLUENT 1 April 6, 2020 19:20
Wall Shear Stress mtl40 Main CFD Forum 3 January 23, 2010 03:08
Problems with wall shear stress. xiexiehezuo FLUENT 1 September 22, 2009 13:26
Re: About wall shear stress Mike FLUENT 9 November 17, 2003 15:41
Wall shear stress in a UDF Jafri FLUENT 3 December 6, 2002 18:29
