May 1, 2003, 05:02 |
Periodic boundary condition
I am simulating a flow problem using periodic boundary condition. Two end of a circular tube consider as translational periodic boundary. According to the fluent documentation, we can specify mass flow rate or pressure gradient for periodic boundary condition. In my case I specified mass flow rate. Now I want to calculate pressure loss to compare with standard friction factor correlation. In the article 8.3.2 of user's guide showed that
Local pressure gradient =gradient of periodic component of pressure + gradient of linearly-varying component of pressure We can get gradient of a linearly-varying component from periodic condition panel. How can we find the gradient of periodic component of pressure? Any help in this regards is greatly appreciated. Arif |
December 22, 2013, 00:14 |
Hi Arif
ASHRAF ALFANDI
Rep Power: 14 |
In this case, the "linearly-varying component = beta" is the actual pressure drop across the your domain in which FLUENT calculates the beta that corresponds to the input mass flow rate. Once the calculation is done, go back to the periodic B.C panel and check "beta" and thats you dp.
good luck..... |
January 17, 2014, 07:48 |
Rep Power: 13 |
Hi everyone!!!
I am trying to simulate a 1d heat transfer in a medium confined between two large walls (top and bottom wall). I created a 2d rectangle in icem cfd. For top and bottom lines I have given the boundary conditions as walls. But I am not clear what boundary condition I should use for left and right lines which are not supposed to be present. (I created them only for meshing).. do I have to use periodic condition? Pls reply. |
March 9, 2017, 02:18 |
#4 | |
soheil
Rep Power: 9 |
in periodic B.C. it gives your pressure drop per metre...that mean total pressure drop per total length of your domain? can we calculate pressure with made two line in your domain and the calculate p(in) & p(out) in these line and the calculate pressure drop? thanks for your help |
periodic boundary condition in LES | martor | FLUENT | 3 | April 30, 2022 01:20 |
mixed inflow/outflow downstream boundary condition question | peob | OpenFOAM Running, Solving & CFD | 3 | February 3, 2017 11:54 |
periodic boundary condition (translational) fluent 6.3 | haihek | FLUENT | 3 | January 22, 2014 05:10 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 03:53 |
translational periodic boundary condition | Rola Afify | FLUENT | 2 | September 12, 2006 09:39 |
