January 7, 2003, 15:21 |
Boundary conditions in Fluent
Hi
I am new to Fluent. Can anybody tell me how do I put a FULLY DEVELOPED inlet boundary condition for pipe flow in Fluent? The velocity inlet conditon gives me plug flow which is not what I want. Thanks Ankan |
January 7, 2003, 22:50 |
Re: Boundary conditions in Fluent
All we can do such a thing is that we have to customize the boundary condition via User Defined Function(called UDF) . Or, how about extend the inlet to be fully developed flow?. I mean , we make the inlet region(called entrance region, or inlet length , enctrance length) This length is given by Boussineq or Nikuradse in laminar flow . Latzko in turbulence. When we make this length ,Fully developed flow is got automatically. This way is the most easy way I guess. Regards, |
January 10, 2003, 21:08 |
For your help further just look UDF manul 1st-3rd chapters and you have a clear idea about your problem.
cheers Alamgir |
March 20, 2016, 12:13 |
#4 | |
Dear expert.. I have to use Superficial gas velocity 0.0016 m/s. But In fluent we have to put Velocity Magnitude at VELOCITY INLET boundary conditions.( INLET VELOCITY) How can I calculate INLET GAS VELOCITY form superficial gas velocity??? ( Reactor dimensions are 20*5*50 cm W*D*L and inlet dimensions are 2.4*1.2 L*D ) |
November 8, 2016, 06:40 |
#5 | |
Rep Power: 15 |
Cheers, Antonio |
November 9, 2016, 04:44 |
#6 | |
Superficial velocity is a velocity that gives the same mass flow rate at any reactor cross-section (or volumetric flow rate, we do not care about density is varying or not - superficial velocity is engineering value based on the mean values). Superficial velocity is just Q/A, i.e. volumetric flow rate / cross-section. As you have circular cross-section for reactor and inlet, the area A is PI*D^2/4. Q is fixed (to hold continuity principle). If you have superficial velocity = 0.0016 for reactor (r-r) cross-section, you have to convert it 0.0016*(PI * Dr-r^2 / 4)/(PI * Dinlet^2 / 4) = 0.0016*Dr-r^2/Dinlet^2. Both D values should be put in the same units! If you have superficial velocity = 0.0016 for inlet, no conversion is needed. |
Boundary conditions in Fluent. | Novice | FLUENT | 5 | March 20, 2016 12:10 |
non reflective boundary conditions for incompresible flow | Pascal_doran | OpenFOAM Programming & Development | 16 | August 25, 2015 06:35 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 06:58 |
asking for Boundary condition in FLUENT | Destry | FLUENT | 0 | July 27, 2010 01:55 |
Import Fluent Mesh and Boundary Conditions | BTU-RoRo | CFX | 3 | July 23, 2010 15:20 |
