Saffman Lift Force: confused
Like Tree1Likes
  • 1 Post By CFD_MAN
Old   November 26, 2002, 19:24
Default Saffman Lift Force: confused
CFD_MAN
Hallo In the Fluent manual, its writtin as: -- The Saffman's lift force, or lift due to shear, can also be included in the additional force term as an option. The lift force used is from Li and Ahmadi [ 135] and is a generalization of the expression provided by Saffman [ 196]:
(19.2.19) [please see the equation in the manual, V6]
where K=2.594 and d ij is the deformation tensor. This form of the lift force is intended for small particle Reynolds numbers. Also, the particle Reynolds number based on the particle-fluid velocity difference must be smaller than the square root of the particle Reynolds number based on the shear field. Since this restriction is valid for submicron particles, it is recommended to use this option only for submicron particles. ---- My question is, after solving a particulate flow (enabling the saffman lift forc), how can I calculate the saffman lift force at a particular location of the particle trajectory? I know particle size, density, velocity and also fluid velocity, so I know Ur, Cd, Rep, but how do I know deformation tensor along the path of the particles?
Any suggestion would be appreciated.
CFD MAN
bob2016 likes this.
Old   November 27, 2002, 13:30
Default did I ask a difficult question?
CFD_MAN
Hallo, Did I ask a difficult or stupid question ?
Until now no ansers !!
CFD MAN
Old   November 27, 2002, 17:52
Default Re: Saffman Lift Force: confused
Amid Naz
Neiter nor, but actually I have no access to the manual..Anyway, to post a question in this forum dont expect quick answer..CHEEEEEEEERS
Old   November 27, 2002, 21:16
CFD_MAN
Have you heard of SLF ? Just curious. FLUENT calculates this force.
CFD
Old   November 28, 2002, 07:22
Amid Naz
I know lift due to shear or the viscous lift force..This definetly can be calculated by Fluent.. but you must select viscous slover not inviscid..Good luck..
Old   September 9, 2010, 05:51
Default saffman lift force estimation
Mohammad
mmmahdavimanesh is on a distinguished road
Dear freinds
I write this termin my code. how should I calculate dij (rate of deformation)?
Assume that particle is within one cell. Is it neccessary to calculate these term in the both side of particle or just derivate and evaluate it in the base of cell?
mmmahdavimanesh is offline   Reply With Quote
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Calculation of Saffman Lift Force JPBodner Main CFD Forum 3 August 4, 2010 12:11
Urgently Need the code of Lift force and VM force Kai Yan Main CFD Forum 0 July 16, 2008 08:07
Lift force or coefficient of lift Rola FLUENT 1 November 12, 2006 14:29
Saffman Lift Force CFD MAN Main CFD Forum 0 November 26, 2002 19:26
