Turbulent Schmidt Number
Like Tree5Likes
  • 2 Post By John
  • 2 Post By Michael Malin
  • 1 Post By CeesH
Old   August 2, 2002, 07:46
Default Turbulent Schmidt Number
John
Hi. For the past few months I have been modelling the movement of neutrally buoyant dye through a pipe with the species model in Fluent 5.5. I have found that altering the turbulent Schmidt number from 0.5 to 1.5 makes a 300% difference to the results. I know Fluent claims that a value of 0.7 is generally OK, but does anybody know if there is more detailed information for pipe flow. Thanks John
villager and IET like this.
Old   August 13, 2002, 08:06
Default Re: Turbulent Schmidt Number
Michael Malin
I don't know about your precise configuration or modelling practices, but for classical developed pipe flow with passive heat or species transport, the turbulent Prandtl/Schmidt number varies from around 0.9 at the wall to 0.6 at the flow axis. Experimental data exists which permits determination of the Prandtl number variation across the pipe. It can be deduced from measurements of the mean velocity profile, mean concentration profiles and the radial profiles of the Reynolds shearing stress and radial turbulent concentration/heat flux.
Old   August 13, 2002, 14:08
John
Thanks for your reply. Can you give me the reference for variation in the turbulent Schmidt number for a pipe? Also is the Prandtl and Schmidt number the same thing? Thanks once again. John
Old   August 14, 2002, 07:50
Michael Malin
I will dig out the reference. The Prandtl and Schmidt number will be the same when dealing with passive contaminents.
Old   August 15, 2002, 03:31
Michael Malin
The references are:
Launder, "Heat and Mass Transport" in Turbulence, Chapter 6, Ed. Bradshaw, Springer, Berlin, (1978).
Reynolds, "The prediction of turbulent Prandtl and Schmidt numbers", Int.J.Heat Mass Transfer, Vol.18, p1055, (1975).
Hinze, "Transport of a scalar quantity in wall turbulence" in Turbulence, 2nd Edition, Chapter 7, McGraw Hill, (1975).
villager and amir.a.aliabadi like this.
Old   August 27, 2002, 10:23
John
Sorry for the delay, but I now have the references. I will have a look and let you know how I get on. Thanks once again for your time. John
Old   August 29, 2002, 12:04
John
I have now looked through the references - I had now idea the issue was so complicated! I have found a further reference you may be interested in:
The height dependence of the turbulent Schmidt number within the boundary layer, Koeltzsh 2000, from the journal of atmospheric environment (I think).
Old   May 31, 2015, 23:36
IET
yunhaifeiyang
IET is on a distinguished road
In Fluent, the default schmidt number is 0.85 for conventional fluid (air and water et al.), but for heavy metal (lead bismuth eutectic et al.), its schmidt number is larger than 1.0. So I want to set it 4.22 instead of 0.85. But I don't know how to do it? Use UDF? Please help me!
IET is offline   Reply With Quote
Old   June 1, 2015, 06:04
Cees Haringa
CeesH is on a distinguished road
If you go to viscous to set the turbulence model, there is a column on the right with a number of constants. if you have species enabled, this will include the turbulent schmidt number as well.
Best,
Cees
villager likes this.
CeesH is offline   Reply With Quote
Low Reynolds number k-E Turbulent Model Sohail FLUENT 19 July 16, 2020 15:08
Problem with decomposePar tool vinz OpenFOAM Pre-Processing 18 January 26, 2011 03:17
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Question on Schmidt number ap Main CFD Forum 0 March 26, 2008 19:58
Turbulent Cylinder Strouhal Number Chetan Kadakia FLUENT 3 October 10, 2002 04:31
