Numerical dissipation/difusion in LES
Like Tree3Likes
  • 2 Post By Ray
  • 1 Post By Steve
Old   June 7, 2002, 07:47
Default Numerical dissipation/difusion in LES
Ray
Dear All,
Can any body talk about numerical dissipation or diffusion in CFD? what's the difference between these two? What's the numerical scheme used in FLUENT 5 for LES? is it highly dissipative?
And if finite-volume method and second-order temporal and upwind spatial discretization are employed, how to deteremine the numerical dissipation?
In large-eddy simulation, how to avoid the subgrid stress being overwhelmed by numerical dissipation/difusion?
Thanks in advance.
Ray
kiddmax and yen like this.
Old   June 9, 2002, 19:31
Default Re: Numerical dissipation/difusion in LES
Steve
Hi Ray,
Dissipation and Diffusion are the same thing. Error that smears out sharp gradients. Dissipation is therefore associated with even order truncation terms usually i.e. a 2nd order derivative in a first order upwind scheme.
I don't know about FLUENT's implementation but LES should be used without any dissipative error - i.e. a central type scheme should be used. These schemes are dispersive i.e. error is spread in a wave like fashion which is evident as spurilous oscilations in the vicinity of steep gradients. These schems have a odd-order leading truncation term.
Error terms can be determined by writing the numerical scheme out as a taylors series expansion and looking at the largest term that has been truncated. You will have to do this both space and time.
Another option is to perform a grid and time step convergence study.
All the best, Steve
EddySouth likes this.
Old   June 10, 2002, 06:15
Ray
Many thanks! Steve.
Numerical oscillations in LES due to mesh refinement Soder OpenFOAM 0 June 14, 2011 11:10
Numerical Implementation of LES Wall models dragon Main CFD Forum 2 March 14, 2005 01:53
problem about numerical scheme in LES. libin Main CFD Forum 4 July 1, 2004 05:32
The numerical scheme in LES? Martin Main CFD Forum 1 May 24, 2004 05:49
the numerical scheme for LES. John S Main CFD Forum 2 March 14, 2004 08:52
