How to obtain mass flow rate of one phase
Like Tree1Likes
  • 1 Post By Derek Jing
Old   May 23, 2002, 22:21
Default How to obtain mass flow rate of one phase
Derek Jing
Who can tell me how to obtain the mass flow rate of one specific phase through one boundary in a multiphase simulation?
I know following three methods: (1)In text command: report/mass-flow (2)In menu: Solver>Monitor>mass flow rate (3)In menu: Solver>Monitor>flow rate>choose phase vilume fraction as the variable.
I tried above three methods, and the results are different. Which one should be correct?
Also, I hope to export the mass-flow-rate vs time data to a file. How can I realize this?
Thank you very much.
-Dejun Jing
mamkol likes this.
Old   May 31, 2002, 14:18
Default Re: How to obtain mass flow rate of one phase
phil buelow
Method #3 is the correct choice, particularly if you have more than one phase flowing through the monitoring surface.
mass flow rate not conserved in turbomachine, interface defined wrong? wildli FLUENT 3 September 15, 2022 13:19
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 22:02
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 15:10
How to change from mass flow to volume flow rate stanley FLUENT 1 February 2, 2007 07:44
mass flow rate of a dispersion phase Paul FLUENT 1 February 26, 2002 00:19
