Direct calculation of temperature gradient
Like Tree1Likes
  • 1 Post By Michal
Old   December 13, 2001, 21:18
Default Direct calculation of temperature gradient
J.W.Ryu
Hi, all.
I am using Fluent 5.5 to calculate thermal and fluid flow on 2d model. To get temperature gradient at specific area, I am conducting bored procedure as follows; 1) Make two lines with constant distance in Interia region (specific area where I would like to know) 2) Save temerature data on these lines as xy file. 3) Caclurate temperature gradient in Spread sheet from xy file.
This work is very tedious and needed time spending. Does anybody let me know how I can get temperature gradient from fleunt directly?
Best regards,
J.W.Ryu
Old   December 21, 2001, 06:33
Default Re: Direct calculation of temperature gradient
H.S.Fang
Hi, How do you get the temperature? Can you show the code? Thanks!
Old   December 22, 2001, 12:07
J.W.Ryu
Hi, I am sorry what the code means. In solid face of 2d model, I make two lines at interior region by entering coordinates x and y.Then, write xy file for temperature of these lines. I calculate temperature gradient from excel spreadshet.
Thanks,
Old   December 22, 2001, 21:21
H.S.Fang
Hi,if I want to add the energy source term ,C_DTDX,to the energy equation,how should I do?The fluent UDF only defines the velocity gradient,the density gradient,and the pressure gradient,but I need the temperature gradient(C_DUDX) every iteration.When I deal with this term in DEFINE_SOURCE,I can't work it out.DO you have some suggests for the problem?Thanks! Happy Christmas!
Old   December 27, 2001, 06:41
Michal
Try this: C_T_G(cell,thread)[i]
,where "i=0,1,2" is the direction. I hope it will be work....
djamila77 likes this.
Old   December 27, 2001, 07:39
H.S.Fang
If I want to direct calculation of enthalpy and species mass fraction, Will C_H_G(cell,thread)[i] and C_YI_G(cell,thread,i)[i] be work?? Thanks a lot!
How to get the temperature gradient in CFX post Jay CFX 4 January 7, 2015 04:23
Averaging 2D Wall Temperature Gradient deji OpenFOAM 2 July 23, 2010 16:06
Cyclic condition for temperature gradient David_010 OpenFOAM 0 May 23, 2010 12:55
Question on Face Temperature Gradient Tomasz Didenko FLUENT 1 June 27, 2003 05:30
UDF reading the temperature gradient Fabian FLUENT 1 May 29, 2003 21:18
