read/write .cas .dat whith C/fortran program
Like Tree2Likes
  • 1 Post By Olivier Wilk
  • 1 Post By alice
Old   October 25, 2000, 05:12
Default read/write .cas .dat whith C/fortran program
Olivier Wilk
Do you know a C or a fortran (free) program able to read/write format file .cas and .dat of Fluent ?
Thank you of you interest.
justsmile2007 likes this.
Old   November 13, 2000, 11:10
Default Re: read/write .cas .dat whith C/fortran program
alice
If you're running Fluent 5, here is an example of C file that allows you to read/iterate/write a case:
/*******************/ rc /path/filename.cas /*read case file*/ rd /path/filename.dat /*read data file/ it 1000 /*iterate*/ wc /path/filename.cas /*write case*/ wd /path/filename.dat /*write data*/ exit /******************/
For more details, have a look in the user guide : "batch execution".
Regards
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
a question of open ".cas" and ".dat" files fanzhong Meng FLUENT 4 May 15, 2006 12:40
Write .cas and .dat for Unsteady TK FLUENT 2 September 12, 2005 06:53
.cas .dat Windows vs Linux K. Jagus FLUENT 2 August 9, 2005 14:58
