November 11, 2024, 15:25 |
Performance using parallel solver
Rodrigo Villarreal
Rep Power: 10 |
Hello everyone,
I have a quick question about the performance of parallel solver in ANSYS FLUENT. My current work station and academic license enables me to run a simulation using 56 logical units. I have 8 FLUENT cases and I want them to run in the same workbench. What will be faster? To use 56 logical units in every case and actualize the project from Workbench, or assign 7 logical units to each project? This may be a dumb question, but thank you for your answer anyway. |
November 11, 2024, 16:36 |
Kareem
Rep Power: 5 |
This will all depend on your specific model and how well it runs with parallel cores. For my work, I almost always find it more efficient run 8 models in parallel then doing each in serial with all cores.
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
November 12, 2024, 03:39 |
Moritz Kuhn
Rep Power: 17 |
I agree with CFDKareem. One reason is that you need also time for data change between the cores. There seems to be a point that the solver then needs more time to communicate between the cores, as you gained by increasing the cores.
November 12, 2024, 13:29 |
Rodrigo Villarreal
Rep Power: 10 |
Thank you both for your answers. It do it in parallel with less cores then.
fluent, parallel, workbench |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 06:02 |
[OpenFOAM.org] Custom solver not running in parallel | syavash | OpenFOAM Installation | 12 | June 6, 2019 16:02 |
Hybrid discretisation - blend factor | gcoopermax | CFX | 5 | September 23, 2016 09:05 |
"Define_Profile" UDF for parallel solver | Antoine | Fluent UDF and Scheme Programming | 9 | February 29, 2016 07:09 |
rhoCentralFoam solver with Slip BCs fails in Parallel Only | JLight | OpenFOAM Running, Solving & CFD | 2 | October 11, 2012 22:08 |
