Continuity residual problem in pipe
Like Tree1Likes
  • 1 Post By xisluke
Old   November 7, 2024, 08:07
Default Continuity residual problem in pipe
Sina Rezvannasab
Sina R is on a distinguished road
Hello
I have a problem with an air flow inside a pipe, the continuity residual does not drop below e-01.
Here are the flow properties: Inlet velocity of 40 m/s and the pressure difference between the inlet and the outlet is 0.3bars.
The piping has a 90 degree elbow in it going upwards.
The length of the pipes connected are 1 and 1.5 meters.
I'm currently using k-epsilon RNG model for the viscosity.
I don't know where the problem is, I've tried two different sets of meshing too. Could you please guide me on a good mesh size (or the number of divisions and inflation) and the suitable "methods" options?
Many thanks in advance
Sina R is offline   Reply With Quote
Old   November 12, 2024, 05:18
Luca
xisluke is on a distinguished road
First of all, residuals are not the only parameters you have to look at when you need to check for convergence; I suggest you to look for physical variables at the inlet/outlet of your domain instead. Generally speaking, in your case residuals are probably affected mostly by the turbulence model, mesh and URFs. If you want to use a k-epsilon model, you can try to adopt the Realizable, with Scalable wall-functions, I think it will be probably more stable than RNG.
Sina R likes this.
xisluke is offline   Reply With Quote
air flow, continuity problem, mesh sizing, methods, pipe bend
[solids4Foam] How to calculate drag coeff when using solids4Foam amuzeshi OpenFOAM CC Toolkits for Fluid-Structure Interaction 15 November 7, 2019 13:50
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
pressure in incompressible solvers e.g. simpleFoam chrizzl OpenFOAM Running, Solving & CFD 13 March 28, 2017 06:49
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
