How to create mesh interface between stators and rotor domain? |
September 30, 2024, 10:44 |
Ariz
Hello, good evening to everyone. Here are my case files being appended. I provided some gaps between domains (inlet, rotor, outlet) and came up with this (first picture). My problem now is the creation of mesh interfaces between domains. I tried to manually create mesh interface between the domains but i am not sure if it is correct. If it is correct, can I proceed already to setup? Thank you very much. Also, I encountered a warning when I tried to write it as one case file in my solution.
October 4, 2024, 15:08 |
Rep Power: 13 |
If it runs and things get conserved, just run it. I am not sure why that warning pops up. I also have had the same often.
October 7, 2024, 01:33 |
Ariz
Ill try to run it. Thank you for your reply. Highly appreciated it
mesh interface rotating, mesh interfaces, meshing, meshing 3d |
