Drag force on specific surface
Like Tree1Likes
  • 1 Post By CFDKareem
Old   August 30, 2024, 06:22
Post Drag force on specific surface
Harisri M Thulasi
harisri is on a distinguished road
I am performing a simulation of supersonic flow across a complex body.
Let us take a car, for example. I have generated an enclosure, subtracted the body from it, gave necessary boundary conditions and made named selections for inlet outlet and car wall. I need to find the drag acting on a specific surface. For eg, drag force on the front glass, drag force on the headlights, etc separately. How to do this?
My difficulty is that when I select drag force while creating a new report definition, only inlet, outlet, and car wall appears in drop-down menu. I am unable to select a specific surface. Any ideas, folks?
harisri is offline   Reply With Quote
Old   August 30, 2024, 15:23
CFDKareem's Avatar
Kareem
CFDKareem is on a distinguished road
You will have to create named selections for the individual faces in meshing. If you name the individual faces named you can calculate the drag force on each face.
harisri likes this.
Please like the answer if it helped!
Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured
CFDKareem is offline   Reply With Quote
Old   September 2, 2024, 01:39
Harisri M Thulasi
Thank you for your prompt answer. Issue resolved.
ansys fluent 2021r2, complex body, drag force
How does ANSYS FLUENT model the surface tension in the Eulerian (multi-fluid) model? mohamedh Fluent Multiphase 8 January 3, 2024 10:07
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
udf for compute pressure drag force fatemi Fluent UDF and Scheme Programming 1 January 26, 2018 14:27
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
