Experimental data validation with Ansys Fluent |
February 28, 2024, 05:50 |
Fawad Ahmed
Rep Power: 3 |
Greetings, I am currently trying to validate my Ansys Fluent model which uses Phase Change Material (PCM) with a paper having experimental data. All conditions in the model are given as per the paper. The data is in good agreement till the phase change and after crossing the phase transition the simulation data shoots up while experimental data goes on with a slight increment. What could be the possible reason? that I should look into my model. I am attaching the graph for your understanding.
February 28, 2024, 14:24 |
Kareem
Rep Power: 3 |
Can you provide a citation for the paper so I can understand the experimental setup?
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
February 29, 2024, 03:49 |
Fawad Ahmed
Rep Power: 3 |
The link to the paper is given below:
https://doi.org/10.1016/j.renene.2022.05.152 PS. My model is a 2D axisymmetric with all the boundary conditions taken from the paper. |
February 29, 2024, 10:01 |
#4 | |
Kareem
Rep Power: 3 |
February 29, 2024, 10:03 |
Fawad Ahmed
Rep Power: 3 |
Yeah I already checked the value and converted it to J/kg
February 29, 2024, 10:16 |
Kareem
Rep Power: 3 |
Ok good. Without looking at the rest of your set-up its hard to say what is causing the error. The paper does a really good job of outlining all the boundary conditions and solver settings. I would just double check your material properties, solver settings, and boundary conditions and make sure there is no discrepancies.
February 29, 2024, 10:18 |
Fawad Ahmed
Rep Power: 3 |
If you say I can send you the case file to ensure the rest of the conditions.
February 29, 2024, 14:02 |
Kareem
Rep Power: 3 |
Yeah send it over in a private message. It may be a few days before I can get to it, but i'll take a look!
Ansys Fluent v232 crash on starting | OmarZaki | FLUENT | 8 | July 31, 2024 04:16 |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
What is the TUI command for writing a data file in Ansys fluent 20 R1? | neelshah0034 | FLUENT | 1 | May 14, 2021 20:52 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
export data from fluent to ansys | galapago | FLUENT | 0 | August 4, 2010 14:04 |
