Does temperature limiter cause solver blow up ? |
December 22, 2023, 11:11 |
Adithya Ajay
Rep Power: 3 |
I know this is a frequent question in the forum. But...
I am running a supersonic nozzle simulation. To keep my Y+ near 1, I am giving a very small first cell thickness, and cells above these have it,s height gradually increased. Hence my aspect ratios are somewhat high near the outlet. I am extending my external domain to give accurate boundary conditions. While running density-based simulations, after soo many iterations temperature is getting limited to 5000K which is not possible physically in my case. But since these high temperatures are not in my area of interest I am neglecting it. But after many iterations floating point errors are arising.All mesh parameters are good ( Min orthogonal quality >0.9, Max skewness < 0.2, Aspect ratio max:333 !!!) My doubts are : 1. Are these temperature limits causing the solver to blow up? 2. I am defining convergence based on net mass imbalance (inflow - outflow)/inflow to be less than 1 % even though my residuals are still in the range of 10^-2 or 10^-3 ( they are oscillating at that range). I am also putting markers around the domain at different locations and plotting velocity against iterations. Is this approach okay? Thank you in advance for the reply. I am posting the image where AR is high and temperature is getting limited. I only care about the inlet ,not on the external domain !!) Last edited by Adithya Ajay; December 22, 2023 at 11:25. Reason: To input more information |
December 22, 2023, 16:44 |
Lucky
Rep Power: 66 |
Yes limiters can exacerbate some problems. >5000K is not physical but once you apply the limiters, now you have jump conditions and super large gradients in the simulation which are even more unphysical.
For example you might say that the maximum temperature expected in my simulation is 300 K and limit the max temperature to 300 K, thinking it is the "physically correct" thing to do. But do so and your simulation blows up even faster. Don't worry about addressing the symptoms, fix the problem. |
December 24, 2023, 16:34 |
Solutions
Adithya Ajay
Rep Power: 3 |
As you can see my mesh metrics except A.R is okay (I think). What else can I do to avoid this large temperature ?
And what's your opinion about the convergence technique in question 2 |
August 14, 2024, 08:34 |
Lily
Rep Power: 2 |
Hello, can I know if you have solved this problem? How was it solved?
convergence criteria, floating point error, supersonic internal flows, temperature limited |
CHT transient solver not converged beacuse of temperature dependent density | KKlee | OpenFOAM | 1 | March 1, 2022 10:21 |
Custom BC (Temperature, cyclic) in compressible solver (rhoSimpleFOAM) crashing | memento | OpenFOAM Programming & Development | 0 | February 14, 2022 07:10 |
Error SIGSEGV using VOF and UDF | JERC_UTFSM | Fluent UDF and Scheme Programming | 14 | November 8, 2021 00:17 |
Divergence in AMG solver: Temperature | Alex07 | FLUENT | 0 | June 17, 2015 16:03 |
divergence detected in amg solver temperature increasing relaxation sweeps | Kashif Rashid | FLUENT | 3 | May 3, 2014 07:23 |
